Author Topic: KUL ES-87 MX Clears: Change from stock ABS OEM prof. to Vortex PBT Cherry prof.  (Read 5749 times)
Offline macguy80
(Had to abbreviate "profile" to "prof." to fit the entire subject)
Would such a change produce any change in its overall feel?
Yes.
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
I...HATE the feeling of MX clears on my pok3r with OEM profile honestly....however the Thick BSP Cherry profile caps on the same board make it feel heavenly honestly.
I refuse to even use MX Clears with OEM profile if that's any indication of how much of a difference it makes in the feel IMO.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline macguy80
I know what my next purchase will be then :) Thanks!
It might be wise to see if you can purchase one single Blank keycap from a website that sells singles.  This would let you experiment before spending the high price Cherry profile keycaps can command.
In you case, could it be the extra weight of the thick BSP keycaps having the side-effect of reducing the weight of the switches slightly?
Offline macguy80
I'd definitely call that a desirable side-effect, for me, anyway. :)
I would definitely say that is a very noticeable and desirable side effect absolutely.  I've tried my Clears using DCS ABS for example and while the shorter profile felt better than OEM on the Clears the thin light ABS of the DCS set felt nowhere near as nice as the thick PBT on the BSP set.   However, i still preferred the DCS set over even the thick OEM PBT sets i have from Vortex and Ducky.
Fair enough :)
I've only used my CODE with the stock keycaps.
Fair enough :)
Should you ever try Cherry profile PBT on your CODE definitely report back, i would be very interested in hearing what you have to say personally about the differences.
Offline macguy80
Profile aside, is Vortex a good brand for keycaps?
Very hit or miss.
I have some sets from them that are done quite well for the $ and others so bad i had to return them...multiple times due to horrible doubleshots on the legends or other issues.  Also the texture on their PBT is not quite as good as other brands IMO.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
lower profile feels better on heavier switches?
my poker 2 has DSA on them and they feel great one issue tho, the keyset feels loose when i transfer them to other keyboards
i dont mind the oem profile on them(mx clears) aswell but granite looks better IMHO
i have varmilo keycaps that are almost cherry profile(Step sculpture 2) could they suffice?
But a friend of mine had a varmilo va87 with MX clears with varmilo PBT keycaps which are tight AF especially on clear stems which seem to be bigger/thicker compared to other mx/clone stems.
He experienced removing a mx clear stem coz he wasnt careful enough about removing the keycaps  :eek:
It's very subjective of course but i have always felt lower profile (Especially thick keycap lower profile) made heavier switches feel a little lighter than they are and far more usable IMO.  I can't stand the feeling of MX Clears with OEM keycaps but for lighter switches like Reds or Browns i can use OEM just fine.
