Author Topic: Aristotle switches back in stock  (Read 90771 times)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
« on: Mon, 08 August 2016, 18:53:14 »
Found some more new old stock. Switches have arrived and now available.
https://zealpc.net/products/taiwan-white-switch-aristotle
« Last Edit: Fri, 09 September 2016, 14:47:54 by Zeal »
Offline Firebolt1914
  • POM Overlord
Re: Aristotle switches coming in tomorrow (August 9, 2016)
« Reply #1 on: Mon, 08 August 2016, 22:01:20 »
These will be NOS, correct?
Offline Zeal
  • * Moderator
« Reply #2 on: Mon, 08 August 2016, 22:02:46 »
Yes, brand new, NOS.
Offline BAS1C
« Reply #3 on: Tue, 09 August 2016, 15:10:00 »
I'm sewwwwww excited :)
*f5*
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4 on: Tue, 09 August 2016, 15:53:56 »
GH I get payed in a week and im sure theyll be gone before then
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #5 on: Tue, 09 August 2016, 15:59:49 »
Oh boy
Offline eksuen
  • Ambassador of explosions.
« Reply #6 on: Tue, 09 August 2016, 16:22:04 »
What is the spring weight of these switches?
Offline BAS1C
« Reply #7 on: Tue, 09 August 2016, 16:24:38 »
>9000
I actually don't know.
Offline Zeal
  • * Moderator
« Reply #8 on: Tue, 09 August 2016, 17:54:59 »
Aristotles live, shipment received.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #9 on: Tue, 09 August 2016, 17:58:31 »
Picked some up. Interested to test them out  :thumb:
« Reply #10 on: Tue, 09 August 2016, 17:58:38 »
Can you set some aside for me? Thanks, bro.
Offline Spopepro
« Reply #11 on: Tue, 09 August 2016, 18:05:32 »
Zeal,
I'm getting an endless loop of my order being processed. Any ideas?
<edit> nvm. Did it on phone. I think there's something with the work firewall. Hopefully i didn't just place 20 orders...
« Last Edit: Tue, 09 August 2016, 18:19:23 by Spopepro »
Offline Zeal
  • * Moderator
« Reply #12 on: Tue, 09 August 2016, 18:20:27 »
Zeal,
I don't see any redundant orders, so it should have gone through properly. Check your email confirmation?
Offline Spopepro
« Reply #13 on: Tue, 09 August 2016, 19:27:12 »
Zeal,
Yep, everything is cool. Something about that computer/connection didn't like the redirect at the end of the process. Thanks!
Offline brighenne
« Reply #14 on: Wed, 10 August 2016, 16:42:00 »
Hey Henry, just a heads up that I noticed your stock check doesn't work when you update quantities within the shopping cart, only when you try to add from the item page. Guessing that's a known issue, but thought I'd throw it out there!
Offline Zeal
  • * Moderator
« Reply #15 on: Wed, 10 August 2016, 16:53:36 »
Not sure if I follow. Adding anything to your cart doesn't guarantee or reserve the item for the user. Inventory levels are only deducted upon successfully checking out.
If you're referring to maxing out the order count at cart, trying to checkout will bring up this page.
Offline brighenne
« Reply #16 on: Wed, 10 August 2016, 17:01:42 »
Ah got it, I just had them in my cart and wanted to check how many you actually had available and noticed it let me put in any number, I see the check is made once you check out.
Offline shangrila500
« Reply #17 on: Wed, 10 August 2016, 17:06:31 »
Got 120! I may be using Zealiostles on my VE.A depending on how clicky they are!
Quick question, how long do you think they will stay in stock? If there are any left next month I plan on ordering more just to keep them for future builds (clicky switches are my jam) but I don't figure you'll have any left.
Offline Jeu
« Reply #18 on: Fri, 19 August 2016, 13:50:44 »
Any videos exist of clicky sound of zealistotles vs blues/greens? Couldn't find any.
« Reply #19 on: Fri, 19 August 2016, 13:52:15 »
Offline Jeu
« Reply #20 on: Fri, 19 August 2016, 14:38:33 »
apparently i didn't look very well....thanks romevi!
« Reply #21 on: Fri, 19 August 2016, 14:52:04 »
With that said, it's not the best way of exampling them.  ;)
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #22 on: Tue, 23 August 2016, 16:17:36 »
I didn't see these until just now! God I need to pay more attention... I'm going to need to buy a load of these to go with my clear stab housing.
And Zealios as well. Fuuuuuuuuuuuuuuuck
Where does one go about lubing aristotles?
« Last Edit: Tue, 23 August 2016, 16:22:10 by katushkin »
Offline Zeal
  • * Moderator
« Reply #23 on: Tue, 23 August 2016, 16:41:03 »
Very light oil on the guiding rails or none...Any bit of lube that gets into the click slider will kill the click.
Offline graefeln
« Reply #24 on: Tue, 23 August 2016, 16:47:08 »
Do you recommend any on the spring or should I just leave it completely unlubed if I am not going to worry about the sliders?
Offline katushkin
  • Just the guy
« Reply #25 on: Tue, 23 August 2016, 16:56:43 »
OK. I probably won't, especially if they one you sent me all those months ago was an un-lubed Zealiostotle. Thanks for the answer in the other thread as well dude, Ima go ahead and order a load of stuff :D
Offline Zeal
  • * Moderator
« Reply #26 on: Tue, 23 August 2016, 17:09:33 »
You can lube the spring without affecting the click slider.
Yeah, that Zealiostotle was completely unlubed. Just put the stem into a Zealio housing with iirc 67g.
Offline Zeal
  • * Moderator
Re: Aristotle switches coming in Thursday (September 8, 2016)
« Reply #27 on: Mon, 05 September 2016, 14:46:35 »
Bump, found some more new old stock. According to the tracking, it'll deliver September 8th.
Offline kawasaki161
« Reply #28 on: Mon, 05 September 2016, 15:00:51 »
mod edit: shhhhhh
Checks out
« Last Edit: Mon, 05 September 2016, 23:19:50 by Zeal »
« Reply #29 on: Tue, 06 September 2016, 08:22:25 »
Sweet.
Offline DanB
« Reply #30 on: Thu, 08 September 2016, 17:19:43 »
Has the Shipment arrived yet?
Kingsaver, Koala
Offline Zeal
  • * Moderator
Re: Aristotle switches coming in Friday (September 9, 2016)
« Reply #31 on: Thu, 08 September 2016, 17:55:50 »
Shipment delivery date ended up being Sept 9. It'll arrive tomorrow. :)
Offline DanB
« Reply #32 on: Thu, 08 September 2016, 19:25:15 »
Would You recommend 67 or 78 springs with them
Kingsaver, Koala
Offline Zeal
  • * Moderator
« Reply #33 on: Thu, 08 September 2016, 19:46:06 »
Spring weight comes down to personal preference...You would really have to go test them yourself and find the perfect balance for your fingers. I personally like the 65/67g weights, but someone else may prefer something heavier or lighter.
« Reply #34 on: Thu, 08 September 2016, 22:33:08 »
Some have reported that they feel heavier than other switches, like the Zealios, with the same springs. Do you find that true from your own experience?
Offline Zeal
  • * Moderator
« Reply #35 on: Fri, 09 September 2016, 14:46:06 »
Package received, aristotles now available again: https://zealpc.net/products/taiwan-white-switch-aristotle
Offline nicckk
« Reply #36 on: Fri, 09 September 2016, 15:33:00 »
Just ordered 40 for the alpha keys on an atreus :) Was pretty bummed about the shipping options though, almost cost as much as the switches themselves...just realized these are shipping from Canada!!
« Last Edit: Fri, 09 September 2016, 15:36:06 by nicckk »
Offline yowaffle
Re: Aristotle switches back in stock
« Reply #37 on: Mon, 12 September 2016, 08:24:02 »
In for some. I added this to my note on the order but just wanted to follow up here too. I'm not dying to get the aristotles right away since im gonna use them on a board I wont have for a few more months.  Is it possible to add my order to my R4 Zealios order?
V60 [MQC] | KC60 [Zealiostotles] | Leopold FC660c [Topre] |  Ducky Shine 4 [MX Brown] | MiniVan [Zealios]
Offline Zeal
  • * Moderator
« Reply #38 on: Mon, 12 September 2016, 10:00:24 »
Order #5017?
I don't see an order note left at checkout, but the order matches your state.
Offline yowaffle
« Reply #39 on: Mon, 12 September 2016, 10:45:29 »
Order #5017?
Thats interesting. Yeah 5017 and 4593. If you already took care of packaging and shipping, its fine tho. Don't want to be a hassle
EDIT: I received the refund for shipping on the order. Thank you so much! I really appreciate it
« Last Edit: Mon, 12 September 2016, 13:39:09 by yowaffle »
