Author Topic: [WTS] BTC-5100 USB modded, NTC KB-6251 (gray Alps, metal plate) USB modded  (Read 2349 times)
Offline TerryMathews
  • Trade Count: (0)
http://imgur.com/a/tbwKG
BTC-5100 keyboard, modified with Pro Micro running TMK. In this state the keyboard supports NKRO. I have flashed the bootloader on the Pro Micro so that it's flashable with DFU instead of having do reset the Pro Micro twice and use avrdude. You can trigger bootloader mode by holding Scroll Lock and hitting backspace. Since it's TMK you can put many more keys on that FN keymap if you want. The keyboard's normal FN key is intact also, so all the double legend keys work as marked.
Foam and foil switches
Made a cable to connect the Pro Micro, original DIN5 cable is included.
$50 shipped CONUS
NTC KB-6251. Alps grey clicky, metal plate, double shot keycaps. Internally modded with Pro Micro using TMK. Scroll lock and backspace to trigger DFU bootloader just like BTC-5100 above.
$45 shipped CONUS
I have feedback at Heatware (https://www.heatware.com/u/3544) and Reddit on Mechmarket and Hardwareswap, as well as eBay feedback as a seller.
« Last Edit: Wed, 10 August 2016, 20:17:54 by TerryMathews »
Offline chicken
  • Trade Count: (0)
  • Gallus gallus domesticus
Re: [WTS] BTC-5100 USB modded, NTC KB-6251 (gray Alps, metal plate) USB modded
« Reply #1 on: Thu, 24 November 2016, 13:13:00 »
pmed
