Author Topic: removed.  (Read 22976 times)
Offline alienman82
removed.
« on: Thu, 11 August 2016, 15:06:12 »
removed.
« Last Edit: Thu, 01 March 2018, 14:55:39 by alienman82 »
Offline 27
  • The Maple Man
Re: [IC] Wyse DCS Cap Set
« Reply #1 on: Thu, 11 August 2016, 15:07:11 »
I was asked to shill here.
PS. I want a set
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline jacobsmirror
« Reply #2 on: Thu, 11 August 2016, 15:07:42 »
Ooo...
Offline sircheddar
« Reply #3 on: Thu, 11 August 2016, 15:09:42 »
maybe sp can clean the dust off the dcs molds and get the lines running rip
" I hope that when the world comes to an end, I can breathe a sigh of relief, because there will be so much to look forward to. "
« Reply #4 on: Thu, 11 August 2016, 15:15:33 »
In fact, there is probably about zero lead time for a DCS set. Should be able to get this one done quickly.
Going through Massdrop, or what?
Offline alienman82
« Reply #5 on: Thu, 11 August 2016, 15:17:33 »
removed.
« Last Edit: Thu, 01 March 2018, 14:56:46 by alienman82 »
Offline mrkevint
  • OK.
« Reply #6 on: Thu, 11 August 2016, 15:53:42 »
I'd be very interested in a set! It's one of my favourite colorways... The yellow arrows are a cool touch. I'm also fine with the DCS profile.
Offline jchan94
  • Keyclack Inc
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #7 on: Thu, 11 August 2016, 16:08:03 »
That kind of looks like olivetti O: just with different arrow keys.
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline alienman82
« Reply #8 on: Thu, 11 August 2016, 16:09:08 »
removed.
« Last Edit: Thu, 01 March 2018, 14:56:52 by alienman82 »
Offline jchan94
  • Keyclack Inc
    • KeyClack
« Reply #9 on: Thu, 11 August 2016, 16:12:28 »
Hmm, that is true. I think the notable differences aren't too distinct in this case.
There's always Tai Hao Olivette
Offline alienman82
« Reply #10 on: Thu, 11 August 2016, 16:18:13 »
removed.
« Last Edit: Thu, 01 March 2018, 14:56:55 by alienman82 »
Offline mrkevint
  • OK.
« Reply #11 on: Thu, 11 August 2016, 17:06:12 »
Those aren't the original manufacturer of WYSE.  I am looking to get as original as possible of a set without compromise on layout.  I've owned those caps and they seemed very cheap compared to DCS.  That set also does not have the caps I am looking for.
How are you planning to do the layout for the bottom row? Also, what is the MOQ for Signature Plastics?
Offline alienman82
« Reply #12 on: Thu, 11 August 2016, 17:20:52 »
removed.
« Last Edit: Thu, 01 March 2018, 14:56:57 by alienman82 »
Offline E3E
« Reply #13 on: Thu, 11 August 2016, 17:30:53 »
Definitely a cool idea and a nice way to retrofit those old Wyse sets after you get those sweet vintage blacks off the board. :P
Offline alienman82
« Reply #14 on: Thu, 11 August 2016, 18:05:49 »
removed.
« Last Edit: Thu, 01 March 2018, 14:56:58 by alienman82 »
Offline duynguyenle
  • Personal text? What personal text???
« Reply #15 on: Thu, 11 August 2016, 18:06:52 »
I already have an old Wyse terminal board (exactly the same as pictured). Would be interested if you could make a child kit that is basically a moggle kit to bring old boards up to standard  :thumb:
1800 support would be sweet too (R1 Delete, End and Pg Down, along with the split numpad plus/minus keys.
« Last Edit: Thu, 11 August 2016, 18:08:46 by duynguyenle »
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline alienman82
« Reply #16 on: Thu, 11 August 2016, 18:10:21 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:00 by alienman82 »
Offline duynguyenle
« Reply #17 on: Thu, 11 August 2016, 19:50:11 »
I will add 1800 support.  Can't believe I forgot that. I don't plan to make a moogle kit as I mentioned in the OP.
I see the updated renders, pretty good coverage overall  :thumb:
Maybe add a R4 1u blank or R4 1u Control? Allows for a bit more flexibility!
Offline mason
  • have fun with her, ryan
« Reply #18 on: Thu, 11 August 2016, 19:56:57 »
I'm interested  :thumb:
Offline KyleZhuang
« Reply #19 on: Thu, 11 August 2016, 22:07:22 »
No doubt, I'm in.
Plus, I think triangle is better than arrow on direction key.
« Last Edit: Thu, 11 August 2016, 22:24:57 by KyleZhuang »
REALFORCE 104 Pro-30
Offline alienman82
« Reply #20 on: Thu, 11 August 2016, 22:27:54 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:03 by alienman82 »
Offline alienman82
« Reply #21 on: Thu, 11 August 2016, 23:24:00 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:11 by alienman82 »
Offline RevoTeam
« Reply #22 on: Thu, 11 August 2016, 23:34:14 »
Great IC. Hope you can make it.Would be killed for a mod kit....
Offline mrkevint
  • OK.
« Reply #23 on: Thu, 11 August 2016, 23:39:47 »
Mockup looks good! It has everything that I would need.
Offline alienman82
« Reply #24 on: Thu, 11 August 2016, 23:47:23 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:08 by alienman82 »
Offline duynguyenle
« Reply #25 on: Fri, 12 August 2016, 05:38:48 »
I will keep you in mind 😘
+1 for a mod kit actually, even though I would get the basekit as well
Offline ideus
  • Björkö.
« Reply #26 on: Fri, 12 August 2016, 06:25:30 »
I'd be interested depending on price. One thing I like better in DCS over Cherry is the extra contoured of its bottom row, they are of course thinner than Cherry, but still, a good option to type, and this color way was originally made by SP. I would suggest you to check the feasibility of adding a 6u space bar for full compatibility with contemporary 1800 key boards that carry 1u mods as well. 6u space bars in a DCS set would be a first, as far as I know.
Offline jaffers
« Reply #27 on: Fri, 12 August 2016, 06:30:21 »
>DCS profile
But why though
Offline duynguyenle
« Reply #28 on: Fri, 12 August 2016, 08:31:01 »
>DCS profile
But why though
Because the original Wyse boards uses them?  ;)
Offline alienman82
« Reply #29 on: Fri, 12 August 2016, 10:19:23 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:13 by alienman82 »
Offline alienman82
« Reply #30 on: Fri, 12 August 2016, 10:35:49 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:15 by alienman82 »
Offline alienman82
« Reply #31 on: Fri, 12 August 2016, 13:21:52 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:17 by alienman82 »
Offline duynguyenle
« Reply #32 on: Fri, 12 August 2016, 13:26:00 »
I'll have to ask about that and the added cost.  Not sure how many people out there use 6u spacebars.  As far as I am aware, every 6u spacebar has an offset stem?  My OG cherry 6u and gateron PBT spacebars both did.
Another concern would be adding more legends to the kit.  This is a total of 6 more keys.
This is more of what you are looking for?
Those 1u mods are perfect! This will have the added benefit of supporting boards like RS68/RS96 with the 3x 1u mods on the right hand side of the spacebar!
Offline ideus
  • Björkö.
« Reply #33 on: Fri, 12 August 2016, 14:38:10 »
Wow! this a comprehensive set for sure, nothing will be missing, and now my wallet should be start being prepared to take another hole in it.
Offline KHAANNN
« Reply #34 on: Fri, 12 August 2016, 14:59:19 »
I would be 99% in, since I'm super curious about DCS, and Midnight makes too much of a statement
Would be nice to have 1.25 blanks, or maybe a Cmd + Meta
Also consider pivoting to a unique, globally appealing colorway, since there might be similar DCS interest waiting to be tapped
« Last Edit: Fri, 12 August 2016, 15:13:22 by KHAANNN »
Offline Dadrophenia
« Reply #35 on: Fri, 12 August 2016, 15:22:36 »
I'm interested, would love another DCS set.
Offline alienman82
« Reply #36 on: Fri, 12 August 2016, 15:29:01 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:19 by alienman82 »
Offline Pliny
  • has 1800 fever
« Reply #37 on: Sat, 13 August 2016, 22:43:59 »
I'd be in as long as you can get that original, funky font. That font + dark blue = delicious!  :thumb:
"He will never, ever give you up. And, most importantly, he will never, ever let you down.”
- Melania T.
« Reply #38 on: Sun, 14 August 2016, 00:01:19 »
I'd say it's a safe bet, since that font is called 'Signature Plastics Default' haha.
Sent from my Nexus 5X using Tapatalk
Offline alienman82
« Reply #39 on: Sun, 14 August 2016, 17:43:13 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:21 by alienman82 »
Offline KHAANNN
« Reply #40 on: Sun, 14 August 2016, 17:49:33 »
~Off topic, what's the deal with that awesome stepped Ctrl in the first pic, I wonder if SP makes more like them
Offline alienman82
« Reply #41 on: Sun, 14 August 2016, 18:01:47 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:23 by alienman82 »
Offline KHAANNN
« Reply #42 on: Sun, 14 August 2016, 18:10:00 »
looks like a stepped 2.25 Ctrl key i think.  you like it ?  :p
I have a thing for stepped keys, otherwise my layouts always have blank spaces :)
Offline alienman82
« Reply #43 on: Sun, 14 August 2016, 18:11:05 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:25 by alienman82 »
Offline duynguyenle
« Reply #44 on: Sun, 14 August 2016, 18:44:35 »
looking at it again looks like 2.5u  that cap is the reason for this GB hahah!
Yes, some Wyse terminal boards have absolutely bonkers layout. I bought a vintage Wyse board earlier in the year, and that one came with an 10u spacebar!
Offline alienman82
« Reply #45 on: Sun, 14 August 2016, 22:21:42 »
removed.
« Last Edit: Thu, 01 March 2018, 14:57:28 by alienman82 »
Offline ideus
  • Björkö.
« Reply #46 on: Sun, 14 August 2016, 22:29:47 »
It would be wise to check if the stems in the 6u space bar fits the Cherry positions, I suppose they should but just double check them.
Picture by infinity.
Offline ideus
  • Björkö.
« Reply #47 on: Sun, 14 August 2016, 22:36:07 »
Also, if you want to make this set a first for a Wyse set, you may explore the use of some Icons, bellow is a picture of some DCS keys SP made for a GB.
« Reply #48 on: Sun, 14 August 2016, 22:57:32 »
I'm almost positive the SP 6u spacebar is centered, not off-centered like the Cherry/GMK ones. I believe they have stabilizer mounts 2u (38.1mm) to either side of the center mount.
Edit: Yes, I just verified both of these facts with my Alpine Winter 6u spacebar.
« Last Edit: Sun, 14 August 2016, 23:00:23 by jdcarpe »
Offline ideus
  • Björkö.
« Reply #49 on: Sun, 14 August 2016, 23:04:35 »
Hum!, that means that adding them, as they are, will be of no benefit for 18XX users; unless, SP has a mold with the off centered stems for 6u space bars.
