Author Topic: Hello  (Read 1797 times)
Offline Trente
Hello
« on: Fri, 12 August 2016, 02:32:12 »
Hello, I have been viewing IC and GB in geekhack for a while but forgot to register an account till now. Recently got a plan for designing and handwiring a keyboard with numpad on left (yep, inspired by Monarch), but got some trouble on picking the right controller. I think Teensy 2.0 did not have enough pin for the build, so should I pick the Teensy ++ 2.0 or the newer Teensy 3.x? If I didn't remember wrong, Teensy 3.x ahve a more powerful chip compare to the Teensy 2.0 and Teensy ++ 2.0. But how should I change my code if I want to use tmk to program the keyboard? Or is it possible I can use those arduino board and TMK to program my keyboard?
Re: Hello
« Reply #1 on: Sun, 14 August 2016, 01:59:33 »
Welcome to Geekhack!
There are not many keyboards with the numpad on the left.  Most of those make my head spin thinking the picture is backwards :))
Not a lot of people check the new members area, so if you don't get a response you could create a thread in the making stuff together section, which will probably get a bit more attention.
