Author Topic: Single GMK Caps?  (Read 3863 times)
Offline mind_funeral
  • savior of lost fortunes
Single GMK Caps?
« on: Mon, 15 August 2016, 12:10:20 »
Is there any way to buy single GMK caps?  I'm in the GB's for Skeletor and Carbon and I want to buy extra "G", "H" and "B" caps so I can mod them to fit around the trackpoint on a Tex Yoda.  Do GB organizers usually end up with leftover caps?  Should I look to GMK?  Kinda lost as this is an odd request.
Any help is appreciated, thanks.
Poker II.3 with Gateron Browns and SIP sockets,  Midnight/Twilight DCS
KBP V60 with Gateron Clears, EnjoyPBT Cyrillics
Topre Type Heaven
Re: Single GMK Caps?
« Reply #1 on: Mon, 15 August 2016, 12:15:34 »
I've never heard of anyone buying single GMK caps and it all depends on how the buy is setup in regards to extras.
There might be a chance if they bought extras sets to use as replacements in case they were needed.
« Reply #2 on: Mon, 15 August 2016, 12:20:03 »
Well, in that case: T0mb3ry, Nubbinator, where y'all at?
Topre Type Heaven
Offline KHAANNN
« Reply #3 on: Tue, 30 August 2016, 12:47:49 »
Just experiment on keycaps you don't use, then apply your perfected method to keycaps you are going to use
« Reply #4 on: Wed, 31 August 2016, 09:03:18 »
It will be done on a mill.  I'm not worried about ruining the caps.  I have more keyboards than just the Yoda and I don't want to use caps with a hole cut in them on my other boards.
Topre Type Heaven
Offline KHAANNN
« Reply #5 on: Wed, 31 August 2016, 09:16:46 »
Buying 2 sets is the solution then
« Reply #6 on: Tue, 06 September 2016, 07:31:12 »
I don't have a need for 2 of the same set.
Topre Type Heaven
