Author Topic: can the Wyse PCE keyboard be directly converted to ps2?  (Read 2070 times)
Offline Aran.E99
« on: Mon, 15 August 2016, 17:45:29 »
I hope this is the correct place to post.
Basically, the DT wiki says it speaks ps/2 protocol. Does this mean I can connect the rj10 directly to a ps/2 jack?
I know that it's probably yes however I have seen nobody do this, only with a teensy.
-Aran
SMK 2nd Gen Blue Alps mount <3
Re: can the Wyse PCE keyboard be directly converted to ps2?
« Reply #1 on: Mon, 15 August 2016, 18:06:43 »
No, only some models speak PS/2. Those keyboards have a cable with a DIN or mini-DIN connector like PC keyboards.
The PS/2 models should have a flat-topped case. The models that speak WYSE's terminal protocol should have a raised box above the function keys.
PS. I'll go check the DT Wiki article to see if I can rewrite it to be less ambiguous. ;)
« Last Edit: Mon, 15 August 2016, 18:11:04 by Findecanor »
Offline Aran.E99
« Reply #2 on: Mon, 15 August 2016, 18:16:44 »
Thanks, that's a shame, I'm not a fan of converters... Thanks anyways.
Offline Aran.E99
« Reply #3 on: Mon, 15 August 2016, 18:22:54 »
My bad, just noticed on DT its listed below terminal only. Guess I will have to get another keyboard to try vintage mx blacks.
Offline klennkellon
  • I like bottoming out
« Reply #4 on: Tue, 16 August 2016, 00:05:10 »
Just get a board with Gateron blacks, they're just as good.
Offline Aran.E99
« Reply #5 on: Tue, 16 August 2016, 07:18:18 »
i've been considering gats. i think my current focus is to get a board with white/blue/green/orange alps. if i get the money, i might just wait for a mx plate to pop up and solder gaterons in.
