Author Topic: HHKB TMK controller: How to use the magic keys?  (Read 2181 times)
Offline tiger
« on: Mon, 15 August 2016, 21:03:02 »
Read through the TMK documentation, and still no idea how to activate the magic keys.
Can someone give a explicit repro steps to activate the magic keys?
For instance, here's one sequence of steps I've tried:
1. Keyboard switch off. USB cable disconnected.
2. While holding down LEFT_SHIFT and RIGHT_SHIFT, slide power switch to on
3. Press spacebar + LEFT_CTRL (salt + magic key to swap control with caps lock)
3.
Offline Tactile
Re: HHKB TMK controller: How to use the magic keys?
« Reply #1 on: Mon, 15 August 2016, 21:13:47 »
I don't think you need the "Left shift + Right shift" combo here. That combo is used elsewhere. Also, I don't know if Boot Magic works with the Bluetooth switch. Hasu only mentions the USB cable.
https://github.com/tmk/tmk_keyboard#boot-magic-configuration---virtual-dip-switch
« Last Edit: Mon, 15 August 2016, 21:51:09 by Tactile »
REΛLFORCE
