Author Topic: White Alps keyboard sticky key  (Read 1856 times)
Offline aquapura
« on: Tue, 16 August 2016, 10:04:23 »
I ended up buying a SGI white alps keyboard. I'm typing on it at the moment. It's quite nice however the 'w' needs to be pushed a little harder for it to register than the other keys. I notice that i tend to push the 'w' key in the upper left corner when i type and i'm not sure if it's just the key or the way i'm pushing it.
I have taken the key off and it looks like normal also the switch feels like normal when being pressed down. I'm thinking about undoing the keyboard and swapping a switch from the say the number pad for the w.... Or is there a way I can get some replacement white switches for this? What do people think?
Any help would be appreciated.
Cheers
Offline mike52787
  • Alps Aficionado
Re: White Alps keyboard sticky key
« Reply #1 on: Tue, 16 August 2016, 10:11:15 »
Cheers
Ill send over a few replacement switches if you pay shipping.
Offline aquapura
« Reply #2 on: Tue, 16 August 2016, 10:14:39 »
Wow that's really kind of you Thanks :D yes I'll pay for shipping. I'll pm you.
Cheers
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Tue, 16 August 2016, 15:44:11 »
In the meantime, Alps switches are very easy to open up and maintence, no soldering is required, just need two flat head screwdrivers. See if you can figure it out.
