Author Topic: New to Site / Mechanical Keyboard  (Read 3328 times)
Offline jjones2
« on: Tue, 16 August 2016, 15:51:04 »
Hey,
So I recently got interested in circuitry and Mechanical keyboards, and had a friend (MrBishop) help me create a custom Ergodox keyboard. He also told me about this site and I thought I would join and check it out. I am interested in doing another PCB build but not really sure what size I want to go with yet.
So now I am looking to get a set of keys for the keyboard and had some questions about the key sizes for the Ergodox modifiers. As this keyboard is not backlight I don't need any crazy keycaps but I would like a matching set without breaking the bank.
I know there are 1, 1.25, 1.5 1.75 and 2+ keys but I cannot really tell the difference looking at them blank spacing or pictures of Ergodox builds on the internet. I wanted to ask if anyone knew the exact sizes for all of the modifiers so I can create a custom set. Also if anyone has an old set of keycaps just collecting dust I wouldn't be opposed to buying second hand keys.
I will try and keep up with this post, but I and pretty bad at keeping up with forums.
Thanks in advanced.
- JJones2
Re: New to Site / Mechanical Keyboard
« Reply #1 on: Thu, 18 August 2016, 06:02:33 »
Welcome to Geekhack!
This Reddit post (sorry) seems to cover that: https://www.reddit.com/r/MechanicalKeyboards/comments/2gnx9o/help_what_keycap_sizes_needed_for_ergodox/
And there's a thread that lists ErgoDox-compatible keycap sets.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Thu, 18 August 2016, 08:37:24 »
Here is the Original & Infinity ErgoDox keycap layout by key size. I hope this helps!
Offline jjones2
« Reply #3 on: Thu, 18 August 2016, 09:04:47 »
Thanks a ton csmertx, this is exactly what i was looking for.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Thu, 18 August 2016, 09:39:43 »
 :thumb:
« Reply #5 on: Sat, 20 August 2016, 06:16:27 »
Great pic :)
