Author Topic: Custom TKL or 90% keyboard parts  (Read 5624 times)
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« on: Wed, 17 August 2016, 16:57:33 »
I just sold some stuff and came up with a good budget for building a proper custom board.
Ideally, I would like to build a 90% board but I can't for the life of me find a 90% case. The Phantom PCB seems like it'd be perfect for this project, as it's readily available and works well with AVR.
What I mean by 90%, assuming that's the correct term is:
TKL, but with the space between the arrows and pg up down del ins, etc. filled in with an additional 5 keys. Traditionally it would be a number pad, which I would like to have available via a function key.
I love the Tex TKL cases but again, I can't find one with an entirely bored out right side.
Can anyone help me out here? I have a lot of experience modding keyboards, lubing, soldering, spring swaps, etc. so that won't be an issue.
This is a picture of what I'm looking to do.
Also, is there a better option for PCB's? I know that the Phantom is popular and for good reason.
Thanks
Bryan
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline Dihedral
  • Mostly Harmless
Re: Custom TKL or 90% keyboard parts
« Reply #1 on: Wed, 17 August 2016, 17:00:22 »
Have you looked at the Lightsaver? I think it's a great looking and functional MTK board
Offline duynguyenle
  • Personal text? What personal text???
« Reply #2 on: Wed, 17 August 2016, 17:29:42 »
You've got a couple of options on the market. Off-the-shelf there's the CM Quickfire TK and Masterkeys Pro M. They both pretty much have the exact layout you want.
If you're set on going custom, You could either hand-wire the keyboard using a plate generated by Swills' tool or get a 96% kit (there's a few that exist on the market, mainly RS96/ZZ96/AMJ96). As another commenter pointed out, Lightsaver is certainly an option, but good luck getting your hands on one.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline xondat
  • i'm not a star
« Reply #3 on: Wed, 17 August 2016, 17:45:13 »
http://winkeyless.kr/product/b-mini-ex-x2-pcb/
I have a feeling this is the closest you'll get without a commission or hand wiring.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #4 on: Wed, 17 August 2016, 17:59:40 »
Ah man. I imagine those acrylic cases feel pretty cheap yea?
I know SPRiT says he makes acrylic cases of all different sizes. Maybe I should try him.
Offline xondat
  • i'm not a star
« Reply #5 on: Wed, 17 August 2016, 18:09:01 »
The cases are some of the communities favorite. They aren't flimsy whatsoever, probably the best of acrylic cases.
I also wouldn't support sprit, considering he still has lots of outstanding customers and since his return hasn't provided any evidence of him shipping things.
If you get the PCB sorted, I could probably get a couple plates machined/anodized and have the layout with a GON style case but probably after I finish my first GB.
Offline duynguyenle
« Reply #6 on: Wed, 17 August 2016, 20:16:40 »
Ooooh I completely forgot about WKL, good spot!
P/S xondat: I saw your 60% group buy, lovely design! It sounds like you've got quite a bit of experience with prototyping, do you have your own CNC?
« Last Edit: Wed, 17 August 2016, 20:24:57 by duynguyenle »
Offline xondat
  • i'm not a star
« Reply #7 on: Wed, 17 August 2016, 20:31:08 »
I don't have my own CNC. I just enjoy creating and will basically take any opportunity to :)) It's why I have like 5 different projects I'm working on, keeps me busy.
Offline Data
« Reply #8 on: Thu, 18 August 2016, 07:45:14 »
Thanks
Bryan
You might want to rethink this.  The Phantom PCB only has 3 columns to the right of the main cluster.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #9 on: Thu, 18 August 2016, 09:36:49 »
Thanks
Bryan
Perfect. Thats what I essentially want; I don't plan on using a number cluster.
Offline duynguyenle
« Reply #10 on: Thu, 18 August 2016, 14:12:17 »
That's cool man, I've got a couple of ideas floating around. Mind if I PM you sometime with a billion questions? I'd like to pick your brain and find out more about your process  ;D
Offline Data
« Reply #11 on: Thu, 18 August 2016, 14:22:50 »
Thanks
Bryan
OK, so really not like the picture at all then?
Offline xondat
  • i'm not a star
« Reply #12 on: Thu, 18 August 2016, 14:30:52 »
Go for it :))
