Author Topic: Changing alps from white to X  (Read 2230 times)
Offline aquapura
« on: Thu, 18 August 2016, 02:19:05 »
Is it possible to replace a keyboard with white alps switches entirely to another color alps switch? I opened up and saw you can take the switch out, But are the other alps switches completely compatible. In other words say i wanted to replace all my white switches with a click blue (assuming i could ever find those) would i just take all the white out and put in the blue or is it more complicated? Sorry for the newbie question
Offline klennkellon
  • I like bottoming out
Re: Changing alps from white to X
« Reply #1 on: Thu, 18 August 2016, 03:31:16 »
It's totally possible, all SKCM/SKCL or Simplified switches should be electrically compatible with eachother, this also includes Matias. It's as simple as just popping out the old ones and soldering the new ones in.
Offline aquapura
« Reply #2 on: Thu, 18 August 2016, 04:24:24 »
Cool :D
Offline aquapura
« Reply #3 on: Thu, 18 August 2016, 08:42:18 »
Oh wow i didn't know I could swap in new matias switches that's pretty cool....
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Thu, 18 August 2016, 08:55:20 »
Matias and Alps are only one-way compatible, though. IIRC Matias parts fit in Alps but not the other way around.
Also not EVERY combination of Alps parts works, but most do :) . The modular nature of Alps is one of their advantages though :) .
Offline aquapura
« Reply #5 on: Thu, 18 August 2016, 08:59:19 »
Thanks Chyros, what's your person view on them in comparison to the original white alps? Which do you prefer ?
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Thu, 18 August 2016, 11:40:14 »
I don't own a Matias board, just a few loose switches, so I couldn't give a proper answer to that. The general view is, which as far as my Matias tester goes, I agree with, is that Matias switches are more tactile, but Alps are somewhat more satisfying. There's virtually no contest about the typing sound, though - Alps switches sound much better.
Offline klennkellon
« Reply #7 on: Thu, 18 August 2016, 15:31:10 »
I found that a spring from an SKCM White switch will work on a Matias switch.
« Reply #8 on: Thu, 18 August 2016, 19:13:36 »
This is probably my next project.
I have an Omnikey 101 in decent shape but I want to populate it with a nice set of orange Alps. So instead of de-soldering all the switches, I plan to leave them in place and pull the guts out of the switch bodies, and replace them with orange internals that I have thoroughly cleaned and inspected.
My mental debate is whether and how and with what I might lubricate them.
I am leaning towards a dry Teflon that sprays on but dries to a very thin residue.
- Bill Roberts 2026-06-17
Offline alienman82
« Reply #9 on: Thu, 18 August 2016, 19:26:15 »
removed.
« Last Edit: Thu, 01 March 2018, 14:16:52 by alienman82 »
Offline mike52787
  • Alps Aficionado
« Reply #10 on: Thu, 18 August 2016, 19:28:29 »
I have a question too.  anyway to put an SKCM stem in an SKCL housing?  I need a couple for Lock LEDs
yeh you just cant have a click leaf of course
