Author Topic: Programmable numpad  (Read 4425 times)
Offline garage_logician
Programmable numpad
« on: Thu, 18 August 2016, 13:20:30 »
Anyone here ever assemble one of these?  Seems like after adding switches, LEDS and a controller(?) it would not be a cheap endeavor.  I would like a separate ten key, one that is programmable.  Are there better alternatives?
https://www.aliexpress.com/item/Digital-mechanical-keyboard-carbon-fiber-shell-digital-pad-kit-digital-key-mechanical-keyboard-shaft/32678512194.html?spm=2114.10010108.1000014.5.kNpsTK&scm=1007.13338.33346.0&pvid=56122a50-80c7-4ac4-bd1d-69af34d4ea42&tpp=1
-g
Offline Tactile
Re: Programmable numpad
« Reply #1 on: Thu, 18 August 2016, 13:52:25 »
There's this one on Massdrop assembled & backlit.
https://www.massdrop.com/buy/kc21-mechanical-numpad
REΛLFORCE
Offline Data
« Reply #2 on: Thu, 18 August 2016, 14:41:12 »
I got mine earlier this week actually.  There's a thread about them in the Making Stuff forum.
Haven't assembled it yet, but I can tell you the controller and other required SMD components are already installed.  You would only need switches at minimum or LEDs and resistors if you wanted to bling it up.  It even came with stabilizers, which aren't pictured.
« Reply #3 on: Thu, 18 August 2016, 14:44:21 »
The ones on MassDrop are not programmable, are they?
Offline Tactile
« Reply #4 on: Thu, 18 August 2016, 14:46:08 »
I think you're right. I missed that one.
REΛLFORCE
« Reply #5 on: Thu, 18 August 2016, 14:46:58 »
Found the forum (had the main forum collapsed!), digging for the thread now.
Thanks
-g
« Last Edit: Thu, 18 August 2016, 14:50:13 by garage_logician »
Offline ryan92084
  • Consumer ****
RiP *ucky Shine(ing)
Offline chuckdee
« Reply #7 on: Fri, 19 August 2016, 11:10:05 »
I don't know anything about this one, but it seems to do what you want.
http://winkeyless.kr/product/b-pad-x2-pcb/#
