Author Topic: A short introdutcion  (Read 3072 times)
Offline AMongoose
  • happy workman user
« on: Sat, 20 August 2016, 19:56:46 »
Hello geekhack,
I program for a living and use mechanical keyboards for fun.
Started using mechanical keyboards some 4 years ago with an iso zowie celeritas with MX browns.
Recently I began using workman as my layout for home and work which led me to use a model M for the ability to freely replace the top caps. While that's pretty fine for house use it's not accepted at my workplace at all so I am searching for some iso keycaps that are not fully sculpted.
I prefer to have my keyboard on my lap.
I hope to have a good time with you all.
Offline reaper
Re: A short introdutcion
« Reply #1 on: Sat, 20 August 2016, 21:49:55 »
And good time you shall have!   Welcome aboard this crazy train.  :)
« Last Edit: Sat, 20 August 2016, 22:07:58 by reaper »
Din Eli
« Reply #2 on: Tue, 23 August 2016, 06:01:03 »
Welcome to Geekhack!
What you want is uniform profile keycaps.
The easiest ones to get are DSA profile from Signature Plastics/Pimp My Keyboard.
You didn't say which country, but MechSupply.co.uk has a very nice navy blue DSA set GB running at the moment: https://geekhack.org/index.php?topic=82150.0
Otherwise you could look for SA sets, which is a somewhat higher profile, but most SA sets tend to be sculptured rather than uniform profile.
Offline AMongoose
« Reply #3 on: Tue, 23 August 2016, 17:55:46 »
Thanks, I'm in europe yes. I'm thinking about this filco doubleshot keyset which seems to have all the function and number rows in one profile and the rest in another profile
« Reply #4 on: Tue, 30 August 2016, 05:53:37 »
Most Filco sets are Filco profile, which is close to OEM profile.
The top row is a bit high compared to the other rows, but that's normal for most sculpted sets.
I have a Filco yellow set which I managed to get after a fair bit of trouble.  It's quite nice, but has started to shine already :(
Offline AMongoose
« Reply #5 on: Tue, 30 August 2016, 08:42:53 »
This last years post seems to indicate that that set is SP SA rows 223333 which would allow for free arrangement of the letters, once I get it I'll report on it.
