Author Topic: MX compatible arcade button caps?  (Read 4015 times)
Offline neverused
« on: Sat, 20 August 2016, 19:57:46 »
Had anyone ever used something like these? The source website has more colors/options:
https://www.focusattack.com/gamerfinger-mix-match-hbfs-30-30mm-cap-translucent-blue/
Sent from my Nexus 6P using Tapatalk
Re: MX compatible arcade button caps?
« Reply #1 on: Sat, 20 August 2016, 20:17:02 »
Not sure if anyone here has, but I remember a discussion somewhere about MX arcade sticks. I'm too afraid to try them. Will stick with Sanwa for now.
« Reply #2 on: Sun, 21 August 2016, 02:06:31 »
sanwas are still better
Offline neverused
« Reply #3 on: Sun, 21 August 2016, 02:07:53 »
I'm sure, but these could make for some interesting/obnoxious function keys
« Reply #4 on: Sun, 21 August 2016, 02:10:51 »
nah just wire up and super glue actual sanwa buttons to some ghetto mount and use that as esc key ez
Offline Giorgio
« Reply #5 on: Thu, 25 August 2016, 07:23:29 »
Sanwas don't have cherry mount, don't they? What product did you buy?
There are a lot of inexpensive buttons, in ebay.com or aliexpress.com, but the don't specify the switch being used.
