Author Topic: I've been making cables!  (Read 2842 times)
Offline SKD
« on: Sun, 21 August 2016, 05:33:48 »
« Last Edit: Sat, 02 September 2023, 06:20:17 by SKD »
Offline SBJ
  • Tactile pls
Re: I've been making cables!
« Reply #1 on: Sun, 21 August 2016, 05:50:47 »
Some nice looking cables.  :thumb:
Looking forward to seeing what's available for order when you get your website up.
Offline Jpecina
« Reply #2 on: Sun, 21 August 2016, 22:29:20 »
The cables look top notch!
Offline tobsn
« Reply #3 on: Sun, 28 August 2016, 16:07:58 »
Would you mind explaining how those are made? Especially the coiling... :D
I'm thinking about making some cables but I'm not sure if one would buy USB cable with or without coating and then pull it through paracord, or if it's easier to just buy it with paracord or shrink PET added from alibaba...
Offline Epic
« Reply #4 on: Sun, 28 August 2016, 19:01:38 »
This is awesome. You should post a how to series :)
Offline KlarKuo
« Reply #5 on: Mon, 29 August 2016, 09:36:00 »
These are nice, dude. Like the coiled ones
Offline SKD
« Reply #6 on: Mon, 29 August 2016, 14:09:26 »
Thank you all  :D
For coiled ones you simply wrap the cables around a rod or pipe, then heat it with hairdryer or heat gun, I use a heat gun. The results do depend on the type of sheath the cable comes with, some will stay coiled better then others. It's all trial and error. You should be able to source the parts online within the same country where ever you're from.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #7 on: Mon, 29 August 2016, 15:39:43 »
Very nice  :thumb:
With Pexon getting bogged down by huge backlog, it's nice to see more people taking up the slack. I like the coiled ones, looks very clean  :D
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
