Author Topic: Selectric Keyboard  (Read 2456 times)
Offline y11971alex
  • Looking for Toronto meetup
Selectric Keyboard
« on: Tue, 23 August 2016, 19:34:39 »
I bought a Selectric that I want to convert to a usable computer keyboard for a leisure project.
I think I'll start by sticking magnetic reed switches close to these latches that are apparently magnetized for some reason.  Each key on the typewriter displaces a distinct number of latches, which is digital information that could be decoded by reading signals from the reed switches.
Offline zzxx6400
Re: Selectric Keyboard
« Reply #1 on: Thu, 25 August 2016, 19:50:47 »
Had the same idea for a while; never got around to actually do it.
I don't think the latch interposers are designed to be magnetic; the soviets swapped in magnetic ones so that their bug would work:
http://www.cryptomuseum.com/covert/bugs/selectric/
Some kind of switch to detect interposer motion is probably needed.
Also, the interposers only move when the typeball moves; that means you will need extra stuff to detect tab, space, enter, shift, and backspace keys.
