Author Topic: 3278 $199  (Read 4345 times)
Offline y11971alex
  • Looking for Toronto meetup
3278 $199
« on: Thu, 25 August 2016, 13:31:36 »
http://www.ebay.ca/itm/311683246131
Some keys seriously knocked over.
Offline pr0ximity
Re: 3278 $199
« Reply #1 on: Thu, 25 August 2016, 13:43:42 »
Dividers between the key clusters have been ripped off too :( Thing must have gone through hell.
Very tempting, but I'm not sure I'm $200-tempted.
Offline HighPlainsDrafter
Re: 3278 $199
« Reply #2 on: Sat, 27 August 2016, 18:51:01 »
Anyone ask the seller whether they have more to sell?
Offline y11971alex
Re: 3278 $199
« Reply #3 on: Mon, 29 August 2016, 19:25:43 »
They just replied: this is the only one.  I obviously believe them.  :D
Offline y11971alex
Re: 3278 $199
« Reply #4 on: Tue, 30 August 2016, 09:57:12 »
On the other hand, it looks pretty beat up.  The manual looks all right though, so all the damage probably came from a crash landing.
Offline pr0ximity
Re: 3278 $199
« Reply #5 on: Tue, 30 August 2016, 10:16:47 »
Yup, I'd grab it and fix it but the case is the big appeal to me and the ripped off dividers make me :(
Just needs to be opened and some switches replaced. Sourcing them isn't easy but isn't impossible. Someone over on DT would probably cough some up.
Sent from my XT1097 using Tapatalk
Offline y11971alex
Re: 3278 $199
« Reply #6 on: Tue, 30 August 2016, 10:58:09 »
orihalcon has some switch testers; wonder if they work.
Offline pr0ximity
Re: 3278 $199
« Reply #7 on: Tue, 30 August 2016, 12:07:03 »
You might be able to bend them back, but they probably wouldn't ever be 100% correct. Not commonly-used keys tho.
