Author Topic: Spacebar feeling funny after changing key caps...  (Read 3611 times)
Offline jdreamer
« on: Thu, 25 August 2016, 22:17:26 »
Greetings all...
I have recently purchased a new set of PBT blank key caps from eBay but after changing to them on my Filco, my spacebar isn't functioning properly. I have to press it real hard to work...
Can someone tell me whether I have anything silly or missed a step? Pressing it hard in the middle bit seems to work but the side, not at all.
My life for Aiur!
Offline SixtyLife
Re: Spacebar feeling funny after changing key caps...
« Reply #1 on: Thu, 25 August 2016, 23:02:03 »
sounds like your spacebar stabilizer isn't properly set. try taking the spacebar off and re-setting it, this time making sure that you connect the stabilizer properly
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline jdreamer
« Reply #2 on: Thu, 25 August 2016, 23:44:18 »
Not sure where did my previous post's gone. Yes, I found out that it's the stabiliser, it keeps coming off. It doesn't stay in place as the holes are a little bit bigger so both the stabiliser will be loosened up everytime I press on it.
Any customed spacebar or suggestions that I can buy? I'm thinking of getting a separate spacebar from imsto directly - http://imsto.cn/index.php?route=product/product&product_id=99 but also afraid that it will be the same issue..
My life for Aiur!
Offline SixtyLife
« Reply #3 on: Thu, 25 August 2016, 23:53:36 »
try cutting a bit of cling wrap or tape and put it over the stem then connect the spacebar. it will give you a tighter fit.
Offline SixtyLife
Offline jdreamer
« Reply #5 on: Fri, 26 August 2016, 00:05:06 »
Oh nice idea, I will give it a go.
My life for Aiur!
« Reply #6 on: Fri, 26 August 2016, 00:53:49 »
Stabilizers are the Devil's work, I swear.
Offline jdreamer
« Reply #7 on: Fri, 26 August 2016, 01:08:07 »
I tried and it still didn't work.. seems like the length isn't right. Haha.. maybe I didn't get the right size or something... Oh wear, less than 18 bucks for a full tenkeyless PBT set, expected error somewhere. :/
Time to hunt for a nice spacebar. Any suggestion? :D
My life for Aiur!
« Reply #8 on: Fri, 26 August 2016, 05:52:15 »
Filco should have a standard layout.  Can you compare the stems under the new space bar with the original Filco space bar?
I use 1cm square sections of a Woolies plastic shopping bag to good effect when stabiliser inserts won't stay in.
Or a thicker plastic, like JB-HiFi has.
Offline jdreamer
« Reply #9 on: Fri, 26 August 2016, 07:28:12 »
rowdy, did you do it the same way like the reddit link?
My life for Aiur!
Offline jdreamer
« Reply #10 on: Fri, 26 August 2016, 23:37:22 »
Just tried with cling wrap and it worked wonder!! THANKS!!! :D
My life for Aiur!
« Reply #11 on: Sat, 27 August 2016, 05:49:31 »
FWIW no, I turned the keycap upside down, put the little square of plastic over the stem, then pushed the stabiliser insert in.
