Author Topic: How to get case underglow?  (Read 3651 times)
Offline Geroximo
« on: Wed, 31 August 2016, 20:13:59 »
Hi,
I have a really silly question.
How do you get a case underglow like this?
I imagine you just solder SMD leds on the underside of the PCB?
Is it that easy?
Also: Do I have to fit a LED in every slot on the PCB to make it work or can I just put a LED on the spots I want to?
Sorry, LED newbie here  :))
Offline Elth
Re: How to get case underglow?
« Reply #1 on: Wed, 31 August 2016, 20:23:44 »
That's a Winkeyless.kr keyboard (b.face I think).
You are correct that there are SMD LED's on the underside of the pcb as seen here:
The case is also either clear or frosted acrylic
« Reply #2 on: Wed, 31 August 2016, 20:26:27 »
SMD LEDs will only work on the bottom if the PCB supports it.  You can solder LEDs into LED spots upside down, but you will forfeit some backlighting.  I know some people have used LED strips on the bottom of the PCB for the same effect.
Offline Geroximo
« Reply #3 on: Wed, 31 August 2016, 20:36:41 »
Ah, I see ... that's what the "SLED" pads on the backside of my NerD60 are for, right?
Offline Elth
« Reply #4 on: Wed, 31 August 2016, 20:44:49 »
The ones for the Nerd PCB are a bit different.
You need ones that look like the ones GON sells on his site:
http://www.gonskeyboardworks.com/electric-parts/14-ledssmd-50-pcs.html
You might be able to find them on Mouser though, and resistors for them to work (if they're not already on your PCB).  Also I think they're only single color and not RGB.
« Last Edit: Wed, 31 August 2016, 20:47:05 by Elth »
Offline Geroximo
« Reply #5 on: Wed, 31 August 2016, 20:57:01 »
Resistors are already on there.
