Author Topic: Topre Realforce 45g uniform (help)  (Read 3505 times)
Offline moh18one
« on: Fri, 02 September 2016, 10:16:09 »
Hi,
I'm looking to buy a 45g uniform Realforce Keyboard but the only model I found is the Topre EK all-45g version. Are Topre Realforce selling a 45g keyboard with white color or an Anniversary version ?
Thanks for the help and sorry for my bad English :(
Offline Sneaky Potato
  • Gunslinger
Re: Topre Realforce 45g uniform (help)
« Reply #1 on: Fri, 02 September 2016, 10:56:03 »
I think that's your best bet on a RealForce in all 45g. Somebody correct me if I'm wrong.
Offline redbanshee
  • actually Dade Murphy
« Reply #2 on: Fri, 02 September 2016, 11:14:57 »
yea I think your right, they never made a white "all 45"
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #3 on: Fri, 02 September 2016, 11:27:37 »
EK or Taobao
http://www.taobao.com/product/realforce-45g.htm
Taobao would have more options but communication/shipping may or may not be a problem. I guess it all depends on your region etc
Offline moh18one
« Reply #4 on: Fri, 02 September 2016, 14:28:09 »
EK or Taobao
Are you sure they sell 45g uniform anniversary keyboard ?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Fri, 02 September 2016, 15:15:26 »
EK or Taobao
It's up to you to look at the listings from different sellers and make up your mind of whether or not they have the product you're looking for. I just copy/pasted an example search for 45g Realforce. I guess if all else fails you might be able to find someone that wants to sell you a Realforce uniform 45g 10th anniversary edition. You only need 25 posts to start a thread in the classifieds section. :)
Offline Tactile
« Reply #6 on: Fri, 02 September 2016, 15:33:41 »
A Realforce 87U 45 gram really shouldn't be too difficult to find if you don't mind a modded one.
Quite a few people buy a 55 gram Realforce and do a dome swap with a HHKB, ending up with a 55 gram HHKB to keep and a 45 gram Realforce to sell.
They turn up in the classifieds sometimes.
REΛLFORCE
Offline losing_ctrl
« Reply #7 on: Fri, 02 September 2016, 21:17:44 »
Hi,
Are you looking for full size keyboard? Here's one non-white version of the 104 keyboard for sale on ebay:
http://www.ebay.com/itm/Topre-Realforce-104-Keys-Electrostatic-Capacitive-Switch-Keyboard-All-45g-PBT-/272114235799?hash=item3f5b45b997:g:95IAAOSwFqJWpDvw
Several months ago I looked for an ANSI, all-white, all 45g version, but did not find any. I ended up buying the JP version below:
https://www.amazon.com/gp/product/B004U8IVK4/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
