Author Topic: Random keys stop working on my Leopold FC200R until it's re-plugged in  (Read 1611 times)
Offline energ1zer
Certain keys (random keys, not always the same ones) will stop working while the rest of the keyboard continues to function properly, and this continues until I unplug and plug it back in. In addition, it will also randomly start "pressing" a key until re-plugged in.
For reference:
-This doesn't happen with other keyboards
-I've tried multiple usb ports
-It's a Leopold FC200R with MX Browns
-I bought it used on /r/mechmarket
-The cable I'm using is radioshack branded, brand new (Is it possible it's caused by the cable? It wasn't forced in or anything)
Thanks in advance for your help, let me know if there is any other information that could help.
« Last Edit: Sat, 03 September 2016, 22:12:36 by energ1zer »
Offline Screwdriver
Re: Random keys stop working on my Leopold FC200R until it's re-plugged in
« Reply #1 on: Sun, 04 September 2016, 00:14:46 »
I'd try another cable.....
Realforce 87U/55g, Deck Hassium Pro-MX Browns, MK Disco TKL - KBT Browns, Code 87-MX Clears, KUL-87 MX Reds.
