Author Topic: A New Way to Clean Your Electronics?  (Read 4538 times)
Offline itlnstln
« on: Mon, 11 January 2010, 15:12:57 »
Check it.  I don't think this will get deep down and clean the dark recesses of your Model M, but it might be good for surface dirt.  Then again, maybe not.
Offline sixty
    • http://deskthority.net
« Reply #1 on: Mon, 11 January 2010, 15:27:31 »
I ordered a six-pack of these a while ago. They are not bad. I use them on my remote control and sometimes on my mouse, never on the keyboard though. Like you said -> It doesn't really go deep enough.
Offline exia
« Reply #2 on: Mon, 11 January 2010, 15:58:11 »
vacuum cleaner is better
Offline AndrewZorn
« Reply #3 on: Mon, 11 January 2010, 17:11:46 »
seems like the kind of thing that would leave a chemical/rubbery smell behind
  • Live long and prosper
« Reply #4 on: Mon, 11 January 2010, 19:04:34 »
I clean the old fashioned way: remove each key and keycap, scrub them really good, and clean out underneath the keys.  A tedious process that takes up about an hour of my time.  Only needs to be done once in a blue moon though, my keyboards stay pretty clean down here in the lab.
tp thread is tp thread
Offline ch_123
« Reply #5 on: Mon, 11 January 2010, 19:07:21 »
Has nothing on my patented 'Keyboard Soup' - add your keycaps to a mixture of lukewarm water, Fairy Liquid and Savlon...
Offline Rajagra
« Reply #6 on: Mon, 11 January 2010, 19:29:46 »
Quote from: AndrewZorn;150129
It's the smell of nostalgia. A seemingly identical product with the same smell was sold as a toy (yes, toy snot/slime, they were simpler days!) when I was young in the 70s. I think they have now just repurposed it. Maybe added the antibacterial property.
It is a kind of chemical lemony smell, but doesn't really linger on whatever you clean with it.
Works OK for removing dust, and as it claims to kill germs I'd say it's an OK product. I suppose the advantage over a simple brush is you're removing the dust not just moving it about.
Offline cheater1034
« Reply #7 on: Mon, 11 January 2010, 20:39:24 »
Probably goes deep enough on that notebook keyboard, not a regular desktop board tho.
And it's obvious that it is only effective at removing loose dirt (atleast when it's used like that guy in the video)- and probably has some bacterial killing agent so it does that too.
But obviously dude, you can't pat a paper towel on dried tomato sauce expecting it all to just come up :P
« Last Edit: Mon, 11 January 2010, 21:51:47 by cheater1034 »
Linux Kernel for desktops: http://zen-kernel.org
IRC: irc.rizon.net #zen-sources
ML: http://groups.google.com/group/zen_kernel
Use it! Supported on any distribution, managed through git.
Current Keyboard: Filco FKBN87M/EB (Brown Cherry)
