Author Topic: 40% keyboard: which one is the easiest to learn and/or most comfortable to use?  (Read 6007 times)
Offline menuhin
I don't know why I'm starting this: because I'm using mostly the 70%-75% keyboards, i.e. those space savers still having the arrow keys. I am still reluctant to give up (or move them to the function layers) the function keys, not to mention the number keys.
However, quite a few 40% keyboards caught my eye: compact size, multiple thumb keys, and the philosophy of shorter finger travel distance (i.e. without R4).
For those who have experienced the 40% keyboard, do you like them? And which one is your favorite? And why?
Here are a few I've read about:
  • Planck
  • JD45
  • JD40
  • Van44 / miniVan
  • MA42
  • kb45p
  • Golbat
  • Minorca
« Last Edit: Mon, 05 September 2016, 18:39:25 by menuhin »
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
I love my JD45 but then again I have only used  a JD45.
Offline chuckdee
I have a Planck, miniVan, kb45p, and two JD45s.
Didn't like the Planck at all.  The lack of the staggered layout really killed it for me.
I love my miniVan for writing.
I use my kb45p on my separate terminal.  It's the smallest of the lot, and is usable even 1-handed.
My JD45/BT JD45 are pretty much the one I use all around to connect to my laptop.  I just need to reprogram the BT one to the default layout; I haven't so far.
Offline Moistgun
  • Slippery When Wet
I can only comment that I prefer the normal layout boards over an ortholinear board.
much easier to learn a new keymap setup when the keys are generally in their normal spot
Offline oneproduct
  • @Ubisoft
I use a Diverge TM, which you can find here: http://unikeyboard.io/
I would say it's likely more comfortable than many other choices due to the fact that it's a split keyboard, though at the same time that could make it harder to learn.
Layout: Colemak
Offline S1llyC0ne
Funny you ! Calling normal a layout designed because of the internals of a typewriter. "Traditional" would be more accurate.
@menuhin : I would have a look at the  Atreus 40%. Typing on a small keyboard can be hard on the wrists since the hands are kept close as long as you type.
Sent from my ONEPLUS A3003 using Tapatalk
Offline PollandAkuma
  • Planck
  • JD45
  • JD40
  • Van44 / miniVan
  • MA42
  • kb45p
  • Golbat
  • Minorca
I really like your username OP. Could you be refering to our one and only Lord?  ;)
I myself was thinking about getting a minivan. But now that I've found Diverge TM, I started thinking about whether I should go for a split ergo like Atreus. Not to mention, Atreus is the very board which atrracted me to this hobby  :rolleyes:
I've literally seen zero videos of Atreus owners doing typing tests on it. I really want to know how it works IRL!
My vote goes for the JD40.
Where can one get a JD40? Haven;t been seeing them around, I've only seen JD45.
PM JD, check classifieds.
I haven't been around for a while, so there might be another outlet.
Offline dilbertprogrammer
  • Keyboard Connoisseur
I've grown fond of the staggered offerings from Panc Co -- the Minorca and the Sebright.
Having the ability to program your own layout makes settling into the form factor that much easier.
