Author Topic: New Leopold Keyboards: FC980M & FC980C  (Read 149747 times)
Offline Entropia
Re: New Leopold Keyboards: FC980M & FC980C
« Reply #250 on: Sat, 14 January 2017, 09:52:20 »
Have anyone already seen how the ISO layout has been designed for these models?
And, have you experienced any problems with the right shift key, both as regard it being a bit shorter and also because it's not stabilized (does it wobble or stuck if pressed on its sides?
« Last Edit: Sat, 14 January 2017, 13:59:09 by Entropia »
Offline davkol
  •  Post Editing Timeout
« Reply #251 on: Sat, 14 January 2017, 14:21:17 »
I've used 1.75u Shift on Noppoo Choc Mini, Cherry G80-1800 and mostly lately Phantom, and there shouldn't be any problem.
Offline Zhuni
« Reply #252 on: Mon, 16 January 2017, 05:15:17 »
Is the 980c key feel lighter then the 660c? I was hoping for something light like the Realforce 45g
[sigpic] [/sigpic]
KBC Poker
Offline Entropia
« Reply #253 on: Mon, 16 January 2017, 06:49:56 »
Are the keycaps on the Leopold FC980M (Topre) printed or dye sub, or does it depends if it's the white or the black model? I've seen some specs where they're supposed to by pbt dye sub, but here it's says they are printed:
http://candykeys.com/product/fc980c-white-ansi
« Last Edit: Mon, 16 January 2017, 12:15:18 by Entropia »
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #254 on: Mon, 16 January 2017, 10:38:01 »
FC980C is dye sub on both white and black
Offline Entropia
« Reply #255 on: Mon, 16 January 2017, 12:14:08 »
A question to all the users of a Leopold FC980: have yo been able to get used to the position of the del key? Or do you find easier to use the numpad del key? In both cases it would be necessary to forget your muscle memory and re-learn, so which one of these positions would be better?
« Last Edit: Mon, 16 January 2017, 12:15:49 by Entropia »
Offline davkol
« Reply #256 on: Mon, 16 January 2017, 12:26:43 »
I've used a variety of layouts and never had to forget the old one, when switching to something different.
I've also used keyboards with Delete in a position similar to FC980 without any issues.
Offline jerue
  • (Whenever that happens :P)
« Reply #257 on: Mon, 16 January 2017, 13:13:41 »
made a few small adjustments to the OP and added order links for those who want to buy  :thumb:
Offline iLLucionist
  • Topre is Love.
« Reply #258 on: Mon, 16 January 2017, 16:58:11 »
So people of the Topre: how does the FC980C stack up against the HHKB and the 87U 55G?
How does Topre 45G plate-mounted feel?
How is the build quality?
That layout looks enticing... mmm... I wanna have babies with it.
Offline harahyuna
« Reply #259 on: Tue, 17 January 2017, 19:14:46 »
Anyone know if Fn+Left arrow will act as Home and Fn+Right arrow will act as End on the Leopold FC980C similar to 660C? Was wondering because on this picture, it states Fn+PgUp instead of arrow keys. http://i.imgur.com/W5qwu8y.jpg
« Last Edit: Tue, 17 January 2017, 20:37:21 by harahyuna »
Offline Rayoui
« Reply #260 on: Tue, 17 January 2017, 20:35:30 »
Up/dn is PgUp/PgDn and left/right is home/end.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline harahyuna
« Reply #261 on: Tue, 17 January 2017, 20:42:47 »
I got them mixed up but does Fn+Arrow keys(Left/Right) work for Home/End on the FC980C though? Someone mentioned it only works with Fn+PgUp/PgDown printed on front keycaps and doesn't work with arrow keys similar to 660C so I'd just like to confirm.
EDIT: Just got the keyboard. Can confirm it works.
« Last Edit: Fri, 20 January 2017, 23:35:01 by harahyuna »
Offline Rayoui
« Reply #262 on: Tue, 17 January 2017, 20:55:14 »
I don't have the board so I can't test but this is from the FC980C page on mechanicalkeyboards.com.
Offline zacho
« Reply #263 on: Thu, 19 January 2017, 13:32:44 »
I just got my second ever mech keyboard, upgrading from a Cooler Master Rapid-I with MX Blues to a black Leopold FC980M with MX Browns (random gift from the brother :P ). I have a GMK Hyperfuse set that i've put on my FC980M but don't have the 1u CTRL and 1U ALT for the bottom row. Any suggestions on single caps that would match the Hyperfuse colorway and profile?
Offline Entropia
« Reply #264 on: Thu, 19 January 2017, 16:04:34 »
What del key are you using, the one that is on the printscreen position or the one on the bottom of the numpad? Both are far from where the del key should be, but I'm trying to get used to any of the new positions.
Offline exime
« Reply #265 on: Fri, 20 January 2017, 10:15:50 »
Wow this layout is genius!!!  I had no idea it existed.   Full keyboards are a couple inches too wide for my preferred keyboard/mouse functuay and TKL is leaving out my beloved numpad.  The two inches in the middle always seemed like a waste as I don't need a dedicated section for scroll lock, pause, insert, home etc..  although I do love delete, it seems to be in a pretty good place.  And let's be honest - I never use my media keys.
Picked up the last White FC980M on MK in Cherry Blue!
Happy to support what I think is the perfect compromise to save 2 inches for mouse space.   Hope this layout becomes a thing because it just makes so much sense.
The only change I'd make as Leopold is swap the location of the delete key and numlock key so that the backspace and delete key are right next to each other.  That would have been total genius. Dedicated Print Screen would be nice too but not sure what it would replace.
 :thumb:  :llama:
« Last Edit: Fri, 20 January 2017, 11:11:31 by exime »
Offline exime
« Reply #266 on: Fri, 20 January 2017, 12:35:43 »
I haven't received mine yet but is there a way to swap the numlock and delete key?  That would definitely complete this layout.
Offline Entropia
« Reply #267 on: Fri, 20 January 2017, 13:43:00 »
I have also considered this possibility. Numlock would look a bit weird outside the numpad, and accompanied by ins, (although it would still be aligned and next to the scrolllock indicator) but the del key position would be closer to the standards and easier to reach. It would also be aligned with backspace, which makes sense. For me it would be very easy to apply this solution: swap the keycaps and let Autohotkey work its magic.
Much better:
« Last Edit: Fri, 20 January 2017, 14:00:36 by Entropia »
Offline exime
« Reply #268 on: Fri, 20 January 2017, 14:51:53 »
Nice!  That's the first thing I'll do when I receive mine then  :cool:
Offline Entropia
« Reply #269 on: Fri, 20 January 2017, 16:26:12 »
Well, actually my plan is this. If I find blank keycaps, it will be perfect. Otherwise I don't mind, as those keys will have useful functions after all.
Offline Entropia
« Reply #270 on: Tue, 31 January 2017, 09:22:22 »
Do you know what's the purpose of the FN combination that allows to choose between n-key rollover and 6-key roll-over? If I plug my keyboard via usb, it's already limited to 6-key, right? And if I'm using PS2, why would I want to limit it to 6-key?
And what about the F1, F2, F3, F4? I've read that's for controlling key repetition. Isn't that already set up by Windows under the keyboard configuration panel?
Offline hking0036
« Reply #271 on: Tue, 31 January 2017, 09:30:42 »
There's some weird work around for usb but yeah it should be limited to 6kro. Some BIOSes have issues with nkro and won't boot so that's why that's there.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline Entropia
« Reply #272 on: Sun, 05 February 2017, 13:23:44 »
I'm waiting for a ANSI FC980M with browns in stock. However, I'm also considering the FC980C, despite its price, because I'd really like to try Topres and have one model with Topres for home and one with MXs for work. The only thing that prevents me from placing my order is the ABS spacebar. Do you know if the black PBT spacebar that is sold by http://www.keyboardco.com matches the original color?
http://www.keyboardco.com/product/topre-space-bar-black.asp
Offline Rayoui
« Reply #273 on: Sun, 05 February 2017, 20:36:32 »
Are you sure that spacebar is PBT?
The stock ABS spacebars aren't that bad. Don't let it stop you from getting a great keyboard!
Offline Entropia
« Reply #274 on: Mon, 06 February 2017, 03:21:49 »
Now that you mentioned it, there isn't any reference about if being PBT. Maybe it's a stock abs spacebar as replacement.
The problem I have with the spacebar is that I always press it on the exact same place, so it gets shiny very quickly.
Offline testplsignore
  • I am one with the Cup Rubber...
« Reply #275 on: Sat, 11 February 2017, 09:50:23 »
Has anyone taken their FC980C apart?
I have a feeling it will similar to the FC660C
Thinking about installing some Hyper rings and MX sliders...
Realforce 10AE 45g Type-S & 55g    HHKB BT & Type-S    Realforce RGB Hype-S    FC980C    FC660C    Filco BT TKL
Offline exime
« Reply #276 on: Wed, 15 February 2017, 12:27:02 »
I'm loving my Leopold FC980M.  Really the perfect layout I hope it stays around in the future.
Offline speaktobrett
« Reply #277 on: Tue, 04 April 2017, 20:37:39 »
Are the FN's for volume control on this keyboard?
« Reply #278 on: Tue, 04 April 2017, 21:41:43 »
Looks like it.
Offline MyNewBoard
« Reply #279 on: Thu, 04 May 2017, 16:21:57 »
Looks like it.
This does not work for my FC980C.
I'm also very curious what that 4th dipswitch does..
Offline avid
« Reply #280 on: Sun, 07 May 2017, 11:11:17 »
A question about the fc980c color. How simular to realforce 87 (in black) is it?
Can you read the fonts in a normal room?
« Last Edit: Sun, 07 May 2017, 11:35:52 by avid »
« Reply #281 on: Sun, 07 May 2017, 14:02:38 »
Looks like same color, different font.
It's legible in a normally lit room, but if you keep your room dark you'll have some issues. Considering it's mostly standard that's not a giant issue, but if you're not too familiar with the layout it might be problematic.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #282 on: Mon, 22 May 2017, 11:00:45 »
Just picked up the FC980C, very nice board, you have the thockiness of a HHKB without the horrid HHKB layout ;D
Offline WarCommand
« Reply #283 on: Mon, 22 May 2017, 11:03:00 »
Girl bye
Offline digi
  • elite af tbh
« Reply #284 on: Mon, 22 May 2017, 15:57:21 »
The Fn + arrow cluster is actually nice for pg up/dn & home / end. Once you remember it's there, it's pretty easy to get used to.
Lovin' it so far.
Thock Thock Thock
« Reply #285 on: Mon, 22 May 2017, 16:03:57 »
Lovin' it so far.
Thock Thock Thock
I totally overlooked that for a while but got used to having home and end on the top row on the right side.
Offline digi
  • elite af tbh
« Reply #286 on: Mon, 22 May 2017, 16:12:16 »
It's almost like Leopold knew I was a mathematician (if you seen some of my posts on GH you'll know that I can pretty much break anything down to an algorithmic level  :)))
« Reply #287 on: Mon, 22 May 2017, 16:16:39 »
It's almost like Leopold knew I was a mathematician (if you seen some of my posts on GH you'll know that I can pretty much break anything down to an algorithmic level  :)) )
digi trade me caps your know you want a storm trooper look :spam:
« Last Edit: Mon, 22 May 2017, 17:14:24 by SpAmRaY »
Offline digi
  • elite af tbh
« Reply #288 on: Mon, 22 May 2017, 16:39:43 »
digi trade me caps you know you want a storm trooper look :spam:
Offline Entropia
« Reply #289 on: Tue, 30 May 2017, 16:44:45 »
I have finally received my FC900 keycap set. I wanted the printscreen and the pause keycaps back to their standard location. I use printscreen for capturing my screen very often. The pause key is for pausing and unpausing my music with foobar2000. The new F2 key is actually for launching this program (I don't need a scrolllock key for anything). The numlock and the delete key have swapped their positions. Now I can reach the delete key easily and it sits in a position that is closer to the standard.
Offline Origami_Rabbit
« Reply #290 on: Fri, 04 August 2017, 21:17:44 »
I really wish fc980c having spare caps lock and ctrl swap keycaps like they did to fc660c.
Anyway, anyone knew where can I get 1.25 topre blank keycaps for the replacement of left ctrl on fc980c?
HHKB Pro JP Type-S with hasu alt controller
Leopold FC980c
Offline prosecutedmind
« Reply #291 on: Sat, 07 October 2017, 16:16:40 »
Anyone know if the 980C has a standard lower row?
« Reply #292 on: Sat, 07 October 2017, 21:45:29 »
Depends on what you call standard.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #293 on: Mon, 09 October 2017, 15:04:43 »
Don't do it, I tried it on my wife's FC660C and it killed all the tactility (hypersphere rings).  Unless you have purple sliders otherwise I'd recommend not mod it (even with purple slider it still reduce travel a tiny bit).
Even my Realforce 104UW is not nearly as tactile as before.
If you want to buy a standard 104 key set and throw it on and everything matches perfectly?  Then no.
You'd have to join a group buy that offers extra keys to get all the keys you want.
Offline Squall
« Reply #294 on: Mon, 15 January 2018, 14:42:56 »
Anyone knows if the 980C will come out in any ISO layout ?
