Author Topic: Brown cherries-- are there several varieties?  (Read 19067 times)
Offline djones
« on: Mon, 11 January 2010, 15:23:01 »
As anyone who knows 67+ keyboards knows, the brown cherries on the MX11800 are not like brown cherries on the filcos-- the filcos seem a bit stiffer at both the initial pressdown and at the "bump-point".  And IIRC the kinesis ergo felt more like the filcos than the mx11800's cherries. Is this simply because of the age of the MX11800?  Or were brown cherries manufactured differently back then?
I ask because I've tried maybe a half-dozen brown cherries and the only one I've felt comfortable for an extended period of time is the mx11800's (which I now own 8 of). I'd like to find a smaller (tenkeyless) board with similar feel but cannot find one.
Offline itlnstln
« Reply #1 on: Mon, 11 January 2010, 15:30:50 »
I think it has to do a lot with the keycaps and switch mounting.  Cherry-made 'boards have PCB-mounted switches and PBT or POM keycaps.  Filcos have plate-mounted switches and (probably) PVC caps.  The combination of all this changes the feel of the switch.  Personally, I find Cherry-made 'boards to be more tactile and a little lighter.  For the record, all of my Cherry brown 'boards were made in the last two years.
Offline sixty
    • http://deskthority.net
« Reply #2 on: Mon, 11 January 2010, 15:31:37 »
I have gone through a similar experience. Most people will tell you that it probably has to do with the difference between PCB and plate mounting. I generally prefer the PCB mounted ones too compared to the Filcos.
On the other hand there is also a rumor that the brown and black MX switches were slightly changed __somehow__ in the 90s. There are a few Korean posts on kbdmania or otd discussing this. Personally I am not sure if this is true, but I also feel a difference between old and new Cherry blacks.
I believe Sandy also has a picture comparing two slightly different brown MX stems. One looks like Caramel and one like chocolate. Confusing, confusing! But nowhere near as confusing as ALPS business.
Offline itlnstln
« Reply #3 on: Mon, 11 January 2010, 15:40:01 »
I think that's just part evolution.  They might use a slightly different plastic composition now than back then, maybe they use a little more dye, etc.  That kind of stuff happens.  I don't think they fundamentally changed the switch, though.  XsPhat had talked to a rep from Cherry one time, and they had told him that that the switches they used for the Cherry-made 'boards were made in a different factory than the switches that are sold to third parties (like Filco).  That's probably a bunch of crap, though.  It doesn't really make any sense.
I will say this, though.  The Cherry browns in my Filcos feel almost linear compared to the SPOS Cherry 'board sitting right next to it.
Offline sixty
« Reply #4 on: Mon, 11 January 2010, 15:57:12 »
Quote from: itlnstln;150104
Exactly!
Offline spolia optima
« Reply #5 on: Mon, 11 January 2010, 16:09:05 »
Though i don't have any conclusive evidence, I'd say that yes, there are two slight different varietiers of the brown cherry
1. the light brown- This is (I think) the version that cherry sells to other manufacturers. Sometimes it's impossible to tell the difference, but i'd say that they're a tad less tactile.
1. the dark brown - I see them in cherry-made boards. They've a bit stronger tactile curve and imho they feel a bit smoother.
Realistically, they're probably use the same exact tooling, but one is made with different materials... hmmm
It might be a generation thing too. We should do some investigating with various brown switches from the last 20 years. This subject is of great interest to me.
edit: After reading the previous posts, I see that I've added nothing new. Basically, I agree with sixty and italian.
Sandy (or perhaps one of the other Oriental Keyboard Aficionados?) made a comparison somewhere, and I may have it bookmarked.
« Last Edit: Mon, 11 January 2010, 16:13:58 by spolia optima »
keyboards!
« Reply #6 on: Mon, 11 January 2010, 16:18:54 »
I'd also like to add that I'm a big fan of the "tea axis" name. It sounds a lot more attractive and inviting than "brown cherry".
keyboards!
Offline itlnstln
« Reply #7 on: Mon, 11 January 2010, 16:23:59 »
Quote from: spolia optima;150114
For the record, there is no difference in color of the stem between my Filco and the Cherry SPOS.  As far as color of the stem goes, I am leaning to simple evolution of the switch through slight changes in materials and dye amounts/materials.
Offline itlnstln
« Reply #8 on: Mon, 11 January 2010, 16:28:04 »
Perhaps ripster would be kind enough to take a picture of the keystems from his SPOS and one he got from DataCal (it would be better if he had one from a Filco, but no need to tear apart one just for this) to see if there is any difference in molding. I suspect not, though. I would imagine the mounting and keycap materials provide all the difference in feel.
« Reply #9 on: Mon, 11 January 2010, 17:21:21 »
Quote from: itlnstln;150119
But there is a difference in feeling, you say?
My ignorance of Cherry's manufacturing history is almost 100%. All I know about the company is that they make a variety of keyswitches, and that their logo is super cute.
That said, I realize that the tea switches in my Compaq 11800 are noticeably lighter (in color) than in my G86 SPOS. Since both boards are made by Cherry, the difference probably lies in the generation/factory/production run- rather than separate switches for OEM/3rd party.
One might say that the tea axis debate is ad nauseam around here. There are also n00bz like me, who haven't heard enough of this discussion and must be educated! It would be nice to sit down and interview someone with the company- a frank discussion about the MX. Just the facts, ma'am.
keyboards!
Offline ch_123
« Reply #10 on: Mon, 11 January 2010, 17:38:49 »
I was about to point this out. Back in Geekhack's early days, xsphat made a thread about a conversation he had with a Cherry employee who told him that Cherry used different switches compared with the ones that they sold to other people. I don't think he found out the specifics though.
Offline hyperlinked
« Reply #11 on: Mon, 11 January 2010, 20:54:49 »
Tea stems? Looks more like coffee nubs or choco-pluses to me.
I don't know if this means that the mounting plays a big role in how a switch feels, but I've noticed that my Choco-Plus Filco feels and sounds different after I switched keyboard trays. I just replaced my old keyboard tray with something much sturdier. I was expecting the keyboard to feel a little different since it'd be more stable, but I was surprised at how it actually sounds different now.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline majestouch
  • * Commercial Vendor
    • http:///elitekeyboards.com
« Reply #12 on: Mon, 11 January 2010, 21:09:30 »
The color of Cherry stems varies quite a bit from lot to lot, regardless of who they're making them for. The level of quality control required to keep the dye consistent between lots is apparently not of concern to Cherry. Any perceived differences in Cherry switches of the same model could be due to all sorts of variables mentioned by other folks here, but the color hasn't anything to do with it as far as I'm aware.
Offline SCTony
« Reply #13 on: Mon, 11 January 2010, 22:35:00 »
IBM PC-AT Model F ;  Model M-
    1391401 Aug 89, 92G7453 Nov 95, 42H1292 Jul 97
Compaq KB-9963 (rubber dome);
Cherry MX-SPOS:typing:
Offline hyperlinked
« Reply #14 on: Tue, 12 January 2010, 01:22:29 »
Quote from: ripster;150202
Two Filco keys.  If you can't detect a difference your monitor is crap.
I see a difference. They misspelled Esc on the one on the left.
Offline ricercar
  • mostly abides
« Reply #15 on: Tue, 12 January 2010, 02:05:00 »
I was feeling inadequate until SCTony posted his pic. Inadequacy is a double whammy when it's instigated by ripster.
Offline Mental Hobbit
« Reply #16 on: Tue, 12 January 2010, 03:27:09 »
Quote from: ripster;150174
I'd rather spread rumors.  I think the BEST Cherry Browns are sold to the Germans.  Just like the Germans like to steal the best beach spots at International Resorts.  This is why they will never sell Cherry Reds to Americans.
Rubbish.
Browns are sold exclusively to those wimps overseas. Germans get clears instead. Experience gained in the daily fight with stiff keyboard switch resistance gives Germans that decisive edge in brawls over the best beach spots at international resorts.
German, US vacationer discussing beach towel placement.
Typing on blues.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #17 on: Tue, 12 January 2010, 05:30:22 »
The big guy there needs to slow down on the twinkies.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline djones
« Reply #18 on: Tue, 12 January 2010, 06:22:17 »
So, what I've learned from this thread is:
1) The switches are the same, but their mounting is different.
  a) The different in color is natural variance in the manufacturing process.
  b) No it isn't, legos!
  c) Your monitor sucks.
2) Their mounting are the same, but the switches are slightly different
  a) And the better ones are sold to germans (never mind which one is 'better')
  b) No they aren't.
  c) Yes they are.
I am so glad we settled all this once and for all.:party:
Quote from: hyperlinked;150232
rofl
Offline meltie
« Reply #19 on: Tue, 12 January 2010, 08:28:24 »
@MentalHobbit: You are absolutely right. THAT is the true conspiracy. I have to IMPORT a Filco from the U.S. to Germany to get a board with brown switches A GERMAN COMPANY PRODUCES. That is, in addition to my Compaq MX11802 that I bought on ebay Germany. I will compare them as soon as the Filco arrives, to see if I agree on the theory of switch deviance.
Offline itlnstln
« Reply #20 on: Tue, 12 January 2010, 09:36:06 »
Quote from: meltie;150280
You couldn't get a Filco from The Keyboard Company in the UK?  It's still not Germany, but at least they're in Europe.
Offline ch_123
« Reply #21 on: Tue, 12 January 2010, 09:47:04 »
Buy a Cherry-made keyboard instead?
Offline itlnstln
« Reply #22 on: Tue, 12 January 2010, 10:00:21 »
I guess that's real point.  It's not the switch, specifically, you're buying, it's the keyboard.  The keyboard is made in Taiwan even though the switch is made in Germany.  Hell, even with Cherry-made 'boards, there's no guarantee that it'll be made in Germany.  I have one made in the Czech Republic and one made in the US.
« Reply #23 on: Tue, 12 January 2010, 10:16:35 »
Quote from: itlnstln;150292
After shipping, taxes, fees and whatnot, it's about the same (obscene) price. But Elite has them in stock most of the time, Keyboardco doesn't.
I'm in the same boat as Meltie, been waiting for a Filco with browns for weeks. Apparently USPS' carrier pidgeons could use some workout on blacks.
Quote from: ch_123;150293
You can't get ANY board with browns in Germany, probably all Europe even. Cherry boards here have blues, blacks or clears.
Typing on blues.
Offline timw4mail
    • https://timshomepage.net
« Reply #24 on: Tue, 12 January 2010, 10:17:58 »
Quote from: Mental Hobbit;150300
It's nearly impossible to find keyboards with Cherry clears in the US, so there seems to be some region-specific switches. (Excepting the Deck, of course).
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
« Reply #25 on: Tue, 12 January 2010, 10:26:51 »
Obviously they feel supersoft browns are only suitable for those degenerated wimps in the U.S. and Japan, while Europeans can deal with some resistance.
German geekhackers should gang together and raid the Cherry factory!
Typing on blues.
Offline lowpoly
« Reply #26 on: Tue, 12 January 2010, 10:31:52 »
MX11800 vs. current Filcos is a difference of several years. Tooling for the switches might have been replaced somewhen. Like new injection molds and new spring fabrication. Cherry is constantly working on cutting costs. Also, the tolerances in the switch specificationes are rather high.
Offline itlnstln
« Reply #27 on: Tue, 12 January 2010, 10:41:37 »
In the disc golf world, as molds for discs break, wear out, etc. and those molds are replaced, discs of the same type will fly slightly differently due to the slight variations in replacement molds (or even different plastic mixes).  I think this might be the case with Cherry (and pretty much anything made out of molded plastic).  Even though the design is essentially the same, slight variations in additional/replacement molds or the blend of plastic that they use, while undectable to the eye, could make a detectable difference in feel or sound.  I don't think they actively make different switches, but I do think there might be slight variances in switches made at different times.
Offline meltie
« Reply #28 on: Tue, 12 January 2010, 10:49:41 »
Actually, Elitekeyboards is even cheaper, especially since I also wanted to buy a HHKB Pro 2, a Fukka and some accessories.
I even mailed Cherry about purchasing a board with browns in Germany, they referred me to their distributor keybo.de. I contacted keybo, and they told me all I could get was clears.
Also waiting for a black US-layout USB G80-3000 with blues to be available in Germany, though. I think the way they make products available in one market and hardly obtainable in the other is irrational.
Offline itlnstln
« Reply #29 on: Tue, 12 January 2010, 10:51:09 »
Quote from: ripster;150312
Faulty logic runs rampant here.
Not to say that I'm not personally guilty of it, but this is exactly the problem.  Logic and business don't mix.  I see it everyday.
Offline msiegel
« Reply #30 on: Tue, 12 January 2010, 11:14:22 »
Quote from: kishy;150322
eBay seller says keyboard clicks.
K: "is it loud?"
Seller: "oh no, it's nearly silent."
;D
Offline watduzhkstand4
« Reply #31 on: Tue, 12 January 2010, 12:03:55 »
Quote from: ripster;150197
Conspiracy!
Note that every single Lego I own is precisely color matched.  For Majestouch to be correct that implies the Danish are more precise than Germans.  This we know is not true.  Therefore the Germans vary the color only for their best Cherry keys.  Which they reserve for themselves the greedy bastards.
the first thing I thought of was the Boomer from L4D
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline itlnstln
« Reply #32 on: Tue, 12 January 2010, 12:10:40 »
I can't decide if the guy on the beach is him:
or him:
Either way, all of these guys are about to give birth to triplets.
Offline itlnstln
« Reply #33 on: Tue, 12 January 2010, 12:56:14 »
He doesn't count; he doesn't have a beer gut.
Offline itlnstln
« Reply #34 on: Tue, 12 January 2010, 16:45:18 »
Quote from: ripster;150387
So.... using DEDUCTIVE reasoning the colors are different but I can't see anything that could be causing the switch to feel any different.
You had better look at the tactile bumps on the stems again.  I can see a difference that is almost as obvious as the color that would explain why the Cherry-made 'board is more tactile.
Offline didjamatic
« Reply #35 on: Tue, 12 January 2010, 16:48:25 »
Those 2 came from completely different molds.  Check the notch on the stems, one is on top, one on bottom.  Also the the dark brown (Cherry board) stems are much sharper on the edges.
Those springs are slightly different.
Offline didjamatic
« Reply #36 on: Tue, 12 January 2010, 16:54:48 »
Your Filco right arrow key should have less than 1% of it's useful life gone, so I think the wear from use isn't the difference.  And you can see sharp edges on areas that will never have any wear such as where the key seats on the stem, that's a sharp edge on the Cherry board switch and a dull one on the Filco.
Maybe one batch was made during Oktoberfest.
OH and great find BTW Ripster, nice work!
« Last Edit: Tue, 12 January 2010, 17:00:04 by didjamatic »
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #37 on: Tue, 12 January 2010, 17:00:40 »
There IS a difference.  See it?
It would seem Filcos use old stock then, as the upper one is what Cherry switch stems traditionally looked like. Apparently they had to redo the entire stem at some point - I wouldn't even be sure whether it still is the same material. The seams are much more obvious, too.
Offline didjamatic
« Reply #38 on: Tue, 12 January 2010, 17:04:19 »
Well, there are at least 3 variations of Cherry browns.
The Filco with the notch on the top of the stem
The Cherry SPOS with the notch on the bottom of the stem
The Compaq MX11800 has no notch in the stem
Offline ch_123
« Reply #39 on: Tue, 12 January 2010, 17:26:32 »
Oh dear god, this is worse than Alps...
Do you know what are simple? Buckling Springs.
Offline ch_123
« Reply #40 on: Tue, 12 January 2010, 17:30:40 »
I mean in terms of construction. The subtle differences between the different part numbers is something of an arcane art, but the actual buckling spring mechanism itself has remained entirely unchanged since 1985.
Offline djones
« Reply #41 on: Tue, 12 January 2010, 20:54:28 »
uuuh, am I the only one who thinks the springs look different?
Offline HaaTa
  • Kiibohds!
« Reply #42 on: Tue, 12 January 2010, 21:40:08 »
Quote from: djones;150435
Dude, you gotta let me know what you're smoking. Its definitely working a lot better than anything I'm using :P.
Kiibohd
« Reply #43 on: Tue, 12 January 2010, 23:18:42 »
Is there any chance that the top stem is just well-used? This comparison reminds me of fjord that I once saw, then saw again 25,000 years later.
keyboards!
Offline elbowglue
« Reply #44 on: Wed, 13 January 2010, 03:36:19 »
MX8100 board has notch at the bottom of the key, just like the G86 SPOS board.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline itlnstln
« Reply #45 on: Wed, 13 January 2010, 07:07:05 »
Quote from: spolia optima;150447
No.  If you look closely, the structure is different.  The top edge of the tactile bump is shorter than the Filco switch.  Wearing down the bump is one thing, but the top edge wouldn't get longer, only shorter.  The dark brown switch is a little closer to the clears than the light brown switch.
Damnit!  I knew I was wasn't just imagining a difference between the Filco and the Cherry.
Offline itlnstln
« Reply #46 on: Wed, 13 January 2010, 07:08:51 »
Quote from: ripster;150415
Spoila, the differences I was speaking of are a little more obvious in this pic.
Offline sandy55
« Reply #47 on: Wed, 13 January 2010, 07:17:59 »
Quote from: ripster;150443
12 windings - standard for Blues and Browns.
Don't know exact method counting windings.
few examples of springs of Blues on different boards )
Offline maxlugar
« Reply #48 on: Wed, 13 January 2010, 10:24:28 »
Quote from: elbowglue;150466
My board has many nothches - the head board on my bed that is!
I guess that explains why my bed springs are also quite worn.   :)
Emperor of the IBM 84-key AT Model F Darkside
Offline itlnstln
« Reply #49 on: Wed, 13 January 2010, 10:25:40 »
Quote from: ripster;150506
Keyboards are different. Switch is essentially the same within manufacturing tolerances.
Yeah, but those tolerances are enough to give one run of switches a noticably bigger tactile bump than another. Looking at the pics, it looks like they changed several things in the stem mold.  For one, they added/removed (depending on which one is newer) an extra "lip" at the top of the tactile part on the switch from the Cherry 'board.
BTW, thanks for taking those pics, ripster.
