Author Topic: TADA68 layout editor question  (Read 6452 times)
Offline Trench
« on: Thu, 08 September 2016, 00:09:14 »
Anyone have any idea what the options under the FN drop down translate to in English? Might be nice to know rather than spend a bunch of time trying to figure it out. Thanks.
Re: TADA68 layout editor question
« Reply #1 on: Thu, 08 September 2016, 02:15:46 »
You might want to add a screenshot - not everyone who speaks the language will have used this keymapper :)
Offline EvilOlivE
« Reply #2 on: Thu, 08 September 2016, 12:12:51 »
this guide helped me https://www.keychatter.com/2015/07/05/programming-the-kc60/
the TADA68 uses the same interface as the KC60
"To switch between layers, set a key to be the Fn key. Then, pick an option from the drop down menu.
The options are:
空操作     –               No operation
瞬时开启层   –       Instantaneous open layer
开启层     –               Open layer
关闭层     –               Close Layer
开关层     –               Switch layer
瞬时开启、 按键Momentary open , button
修饰键     –       Modifier keys
组合键     –       Key combination
单击修饰键   –       Click modifier keys
开关修饰键   –       Switch modifier keys
清除层状态   –       Clear layer status
宏       –       Macros"
Offline Trench
« Reply #3 on: Thu, 08 September 2016, 19:40:26 »
THANKS! Exactly what I was looking for.
