Author Topic: aluminium top plate thickness  (Read 4200 times)
Offline kingyachan
« on: Thu, 08 September 2016, 19:25:18 »
Hey,
So I'm getting some laser cutting done on some mounting plates for a project I'm working on, however, I hadn't thought about how thick it should be.
I'm guessing that 1.5mm or 2mm is probably about what is required but I anyone with a bit more experience with making mount plates could give me some more info on this that would be great.
As the title suggests I'm using aluminium  :thumb:
Thanks in advance!
Offline MajorKoos
  • 1 life please. Extra large.
Re: aluminium top plate thickness
« Reply #1 on: Thu, 08 September 2016, 19:34:09 »
This is what I've been using:
 - 1.3 for alps.
 - 1.5 for MX.
Offline MediocreBadGuy23
« Reply #2 on: Thu, 08 September 2016, 19:40:06 »
I've always done 1.5mm for aluminum and 3mm for acrylic
Offline xondat
  • i'm not a star
« Reply #3 on: Thu, 08 September 2016, 19:47:29 »
1.5mm allows the Cherry switches to clip into the plate, anything thicker and you can pull them out quite easily.
Offline kingyachan
« Reply #4 on: Thu, 08 September 2016, 19:49:09 »
Oh excellent, is 1.5mm pretty sturdy?
Offline xondat
  • i'm not a star
« Reply #5 on: Thu, 08 September 2016, 19:50:19 »
For aluminium/steel, it's plenty. Polycarbonate/acrylic is doable at 1.5, it's just a bit "riskier".
Offline MajorKoos
« Reply #6 on: Thu, 08 September 2016, 19:59:37 »
Agreed.  In a pok3r style case where the PCB takes the load 1.5mm can work, but 3-5mm for sandwich or hardwired.
Offline kingyachan
« Reply #7 on: Thu, 08 September 2016, 20:24:48 »
Brilliant!! thanks guys!
Offline kolec94
« Reply #8 on: Fri, 09 September 2016, 16:31:46 »
what grade of aluminium are you using because it can effect strength
kbparadise v60 blues
Offline kingyachan
« Reply #9 on: Fri, 09 September 2016, 18:13:55 »
ummm no idea? what would you suggest?
Offline duynguyenle
  • Personal text? What personal text???
« Reply #10 on: Fri, 09 September 2016, 18:52:01 »
6082 or 6063 are pretty common grades of ally
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
« Reply #11 on: Fri, 09 September 2016, 19:33:05 »
Do use 60xx-series if you can find it. 30xx-series might be more common for sheet alu and is not as tough - but should still be better than 1.5 mm acrylic.
Offline kolec94
« Reply #12 on: Sat, 10 September 2016, 00:34:56 »
best strength would be a 70xx series aluminum but a 60xx should be fine
