Author Topic: DOLCH Color Scheme?  (Read 5404 times)
Offline OrcsInSpace
DOLCH Color Scheme?
« on: Fri, 09 September 2016, 12:50:01 »
How does one go about getting PBT keycaps in a certain color. I really want Cherry/PBT keycap set in dolch color scheme!
Re: DOLCH Color Scheme?
« Reply #1 on: Fri, 09 September 2016, 13:41:14 »
The real Dolch keycaps have white legends. To get durable lighter legends, the legends would have to be double-shot moulded or in-filled. Dye-sublimation can only produce darker colours.
Double-shot PBT and in-filled PBT are still both uncommon... I think only Vortex does either and I have not seen them do the Dolch colour scheme.
It might be possible to find two sets of blank keys in almost the correct shades.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Fri, 09 September 2016, 13:42:37 »
whoa this is some good information. i didnt know that about dye subbing
but you can actually buy gmk dolch keycaps. theyre around 150-200$ though. there was  group buy that just ended for it
« Reply #3 on: Fri, 09 September 2016, 14:54:32 »
Yes, and GMK's are the real deal, exactly like the original.
There have also been keycaps in a Dolch-like colour scheme from Tai-Hao in OEM profile. And there have been DSA-profile keys from Signature Plastics in Dolch colours but with centred legends.
But all of these are double-shot ABS, not PBT.
« Last Edit: Fri, 09 September 2016, 14:56:20 by Findecanor »
