Author Topic: Varmilo profile vs cherry profile  (Read 21986 times)
Offline letsjigsrocks
  • Don't you think its cute?
« on: Sat, 10 September 2016, 08:29:17 »
Is Varmilo using Step Sculpture 2 (SS2) or Cherry Profile?
As far as I know, its SS2. My question, is SS2 profile same with cherry profile?
I'm torn getting a cherry profile for two-tone but I don't know if it will be compatible to my Varmilo stock keycap.
« Last Edit: Thu, 15 September 2016, 02:13:37 by letsjigsrocks »
VA87MR
Offline Birdsht
Re: Step Sculpture 2
« Reply #1 on: Sat, 10 September 2016, 09:08:54 »
« Reply #2 on: Sat, 10 September 2016, 10:32:21 »
I'm shocked of this. never thought of it that it is OEM. Is this updated?
VA87MR
« Reply #3 on: Sat, 10 September 2016, 11:16:47 »
Took shot of my board. It seemed to be more cherry profile than OEM. The ESC row and NUMBER ROW are the same.
Never mind the plate(It's just bond paper :)) :)))
« Last Edit: Sat, 10 September 2016, 12:31:09 by letsjigsrocks »
VA87MR
Re: Varmilo profile vs cherry profile
« Reply #4 on: Thu, 15 September 2016, 02:21:46 »
Anyone here could mix cherry profile and varmilo caps? How is it?
VA87MR
Offline silaz
« Reply #5 on: Sun, 18 September 2016, 20:31:11 »
This is really shocking, I was fairly convinced Varmilo was SS2! The more you know...
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #6 on: Mon, 19 September 2016, 00:23:50 »
There is no way in hell varmilo keycaps are OEM. I have ducky pbt OEMs and they are too high compared to my varmilo stock keycaps.
Varmilo are SS2, almost cherry profile.
Edit*
Proof
varmilo with SS2 profile
Tai-hao with OEM
R1 side by side comparison
more photos here: http://imgur.com/a/KueuL
« Last Edit: Mon, 19 September 2016, 09:21:00 by potatobot »
Offline nyunyu
« Reply #7 on: Wed, 21 September 2016, 06:33:42 »
What is the height of the Esc key on Varmilo caps?
For comparison OEM caps are 14mm high, Cherry profiled caps are only 10mm:
Left to right: Cherry MX-Board 2/3 (ultralow profile), Gateron blanks (Cherry profile), Max/WASDKeyboard (OEM), vintage BTC (almost Cherry profile)
Offline nyunyu
« Reply #8 on: Wed, 21 September 2016, 07:03:21 »
If you have white Varmilo caps, then you can try dyeing them yourself.
PBT can be colored very easily with nylon dyes. (Dylon MultiPurpose, Rit, iDye)
I was playing a bit with Dylon:
Full process: http://imgur.com/a/Eovom
I wanted light blue mod keys, but I messed up the cooking time, PBT needs around 10 minutes.
(Earlier I tried to dye an ABS set, which was barely colored after 30 minutes, even after I added 200ml acetone as thinner)
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #9 on: Wed, 21 September 2016, 08:37:35 »
im interested to try this. if my caps have dye sub, would the prints be covered?
i wanted to have cyan + dark grey caps
Offline nyunyu
« Reply #10 on: Wed, 21 September 2016, 09:39:15 »
There are a lot of good dyeing guides on Deskthority, like this one:
https://deskthority.net/workshop-f7/dylon-dyeing-of-pbt-caps-more-experiments-t5433.html
