Author Topic: Searching for cheap old styled mechanical keyboard  (Read 4772 times)
Offline Dont Touch Me
« on: Wed, 14 September 2016, 09:57:02 »
im searching for vintage mech keyboard , this is the best "look alike" old styled mech keyboard i can found on my online retailer store , actually i dont really know which one is mechanical or membrane , which one do you guys think have the highest possibilty to have a mechanical switch under  their keycaps  ? thanks  :D
(1)
« Last Edit: Wed, 14 September 2016, 09:59:35 by Dont Touch Me »
Offline Tactile
Re: Searching for cheap old styled mechanical keyboard
« Reply #1 on: Wed, 14 September 2016, 09:59:32 »
Get the Model M. Number 4.
REΛLFORCE
« Reply #2 on: Wed, 14 September 2016, 10:01:47 »
what kind of switch is used on that keyboard ? , that keyboard have the highest price range than the other though .....
Offline Tactile
« Reply #3 on: Wed, 14 September 2016, 10:06:48 »
It is a buckling spring keyboard. It's also one of the most legendary keyboard types ever made.
If you Google "Model M" or "buckling spring keyboard" you'll find lots of info.
REΛLFORCE
Offline mike52787
  • Alps Aficionado
« Reply #4 on: Wed, 14 September 2016, 13:51:08 »
Another good old looking board is a dell at101w or northgate omnikey. classic looks and great switches.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Wed, 14 September 2016, 15:02:40 »
Of those posted, get the Model M. If you want something cheaper, like Mike said, get an AT101.
Offline keyladding
« Reply #6 on: Thu, 15 September 2016, 06:38:29 »
Offline Tactile
« Reply #7 on: Thu, 15 September 2016, 08:17:27 »
REΛLFORCE
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Thu, 15 September 2016, 08:31:33 »
Model M
« Reply #9 on: Thu, 15 September 2016, 12:15:36 »
Oh, I mistook the list for a signature at first...
The Model M is the only one in the list that is mechanical.
Offline klennkellon
  • I like bottoming out
« Reply #10 on: Thu, 15 September 2016, 20:13:34 »
The only one in that list worthwhile is Number 4, which is an IBM Model M. However with Model M's there is always a chance it could be one of the "quiet touch" variants which are a rubber dome.
« Reply #11 on: Thu, 15 September 2016, 20:36:42 »
I don't think that the rubber dome ones (part number 7*) have removable caps.
- D Trump 2026-10-24
Offline klennkellon
« Reply #12 on: Thu, 15 September 2016, 20:38:24 »
ah that's true. probably fine then.
Offline Rayndalf
« Reply #13 on: Sun, 18 September 2016, 02:55:31 »
I would recommend a cherry 11800 / 11900 (most 11800's branded as compaq). They run about $50 or less and offer black or brown mx switches, cherry profile keycaps and a track ball or track pad.
