Author Topic: Anyone have defects with 1976?  (Read 5061 times)
Offline captsis
  • Formerly matt2dlg
« on: Wed, 14 September 2016, 23:41:41 »
Pretty much all of the caps i received were nicked. Am currently waiting for massdrop to send me a replacement stepped capslock(printed upside down) and a 1.5 capslock that wasnt included  :(
Offline captsis
  • Formerly matt2dlg
Re: Anyone have defects with 1976?
« Reply #1 on: Tue, 20 September 2016, 01:45:46 »
Bump? :-X
Offline Gajible
« Reply #2 on: Tue, 20 September 2016, 01:47:13 »
Nicked? You mean the sprue mark?
Offline captsis
  • Formerly matt2dlg
« Reply #3 on: Tue, 20 September 2016, 01:59:01 »
Thats what I thought it could be? but for each key the mark is in a different place. Some of the tops of the keys looks like it was scratched with a knife. Not swirls but like straight. The best analogy I can think of is when someone keys a car and you can see the clear coat. All of the sprue marks ive seen arent like that.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #4 on: Tue, 20 September 2016, 11:04:53 »
Pix would help a lot, but that does sound awful
Offline Geroximo
« Reply #5 on: Tue, 20 September 2016, 14:33:36 »
Do not expect anything from Massdrop support.
Offline chuckdee
« Reply #6 on: Tue, 20 September 2016, 15:09:16 »
I haven't ever had any problems with them, other than marginal slowness.
Offline captsis
  • Formerly matt2dlg
« Reply #7 on: Tue, 20 September 2016, 15:16:38 »
I emailed them 2 weeks ago asking for a 1.5u BS and a stepped Caps (the bs wasn't included and caps was printed upside down). Got A response a day later saying they would "attempt to order replacements, but be aware it may not be possible to do so". Even GH buys (which are more risky IMO) attempt to send replacements. >:(
Offline chuckdee
« Reply #8 on: Tue, 20 September 2016, 18:51:31 »
That's unfortunate, but they said that they would attempt to order them.  What else do you want?  At that point, it's up to whether SP will do the one offs, right?  It's not like they said you're just out of luck...
Offline captsis
  • Formerly matt2dlg
« Reply #9 on: Tue, 20 September 2016, 21:47:13 »
Every GB ive seen on here sends off replacements. Isnt massdrop the one that sorts the caps? Its not like its my fault the caps have defects
Offline chuckdee
« Reply #10 on: Wed, 21 September 2016, 03:37:14 »
They didn't say that they wouldn't.   They were just setting expectations in case SP can't/won't send replacements.
Offline el_mechacontext
  • You can find my body in the mechacontext.
« Reply #11 on: Wed, 21 September 2016, 17:56:20 »
Yes! One or two of mine were nicked, not a cast mark but some kind of shipping defect I believe. It's not visible in use but a little off-putting. Oh well! :(
Pok3r MX Clears | CM Storm Stealth MX Blues | Dell AT101W Alps Blacks | Happy Hacking Keyboard Uni 45g | Ortholinear Planck Gateron Blacks
Offline captsis
  • Formerly matt2dlg
« Reply #12 on: Wed, 21 September 2016, 17:58:38 »
Best of luck
