Author Topic: Help troubleshooting a ps2avrU keyboard!  (Read 3032 times)
Offline Donbabbeo
« on: Sat, 17 September 2016, 06:40:55 »
it worked just fine, then one day it began acting weird with key stuck (not the switches, like pressing a key without releasing it) and the only way to stop it was plug/unplug.
Then one day when connected, Windows keep bragging about a USB device not found. Changed cable, tried different PC and USB port but nothing.
If i keep pressed Y or U it's being recognized, but only for few seconds then no key sent. If i try flashing, it says device unrecognized.
Any help/advice?  :(
Offline captsis
  • Formerly matt2dlg
Re: Help troubleshooting a ps2avrU keyboard!
« Reply #1 on: Tue, 20 September 2016, 21:58:43 »
Maybe a joint came loose? Check your soldering for any obvious issues.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #2 on: Tue, 20 September 2016, 23:58:20 »
This is why i always have a copy of my original/out of the box layout for instances like these.
Offline Donbabbeo
« Reply #3 on: Wed, 21 September 2016, 13:31:31 »
First thing watched. Nothing to report  :(
What do you mean? If you are speaking about firmware layout, i didn't mess with it.
When it started acting weird it was with the same firmware as it was when i bought it.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #4 on: Thu, 22 September 2016, 08:05:38 »
Then maybe the issue persist with the controller itself.
Might be defective or your usb port was undervolted? have you ever experienced it with other devices before?
Offline Donbabbeo
« Reply #5 on: Thu, 22 September 2016, 15:32:24 »
Nope, first time it happened to me. I suppose the only solution is to trash it  :(
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #6 on: Fri, 23 September 2016, 01:26:00 »
shame, you can always find replacement pcbs tho :D
Offline Donbabbeo
« Reply #7 on: Sat, 24 September 2016, 07:47:45 »
Yup, i discovered that i'm not a 60% person, but i paid more for the case than the rest, so i don't want to trow all away :D
It's seem that i'm in the market for a 60% pcb  ;)
