Author Topic: [IC] Sky Dolch - Phase 2 [NOW LIVE!]  (Read 462526 times)
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: [IC] Sky Dolch - Phase 2
« Reply #50 on: Thu, 22 September 2016, 00:49:16 »
Would you guys want to see a Dolch. Esc or Windows in the original font?
Could you show a mock-up to better illustrate what you mean? Like the Serif font of the Dolch logo?
http://imgur.com/a/oRbo2
Yes sir
Offline shower_king
  • Pain is weakness leaving your body
« Reply #51 on: Thu, 22 September 2016, 01:48:16 »
Yes sir
i perfer "dolch" ESC to "dolch" win. :thumb:
Offline duynguyenle
  • Personal text? What personal text???
« Reply #52 on: Thu, 22 September 2016, 02:09:23 »
Yes sir
I think Dolch Esc is the way to go, always preferred win keys to have icon
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline potatobbq
« Reply #53 on: Thu, 22 September 2016, 04:21:40 »
Really like the SoWaRe style multicolor modifiers :thumb: Would love to add these to my existing Sky Dolch!
Offline codedisorg
« Reply #54 on: Thu, 22 September 2016, 10:45:16 »
Definitely want the old R1 keys + anything missing to cover a 65%.
Prefer a double shot win/meta key (vs pad print) so whatever logo works for that will work for me. Are the win95 keys extra or being offered instead of the original win8 logos? It's a little difficult to keep track of with the variance in windows logos (8 for original run, 95 in the cyan keys, and XP for everything else).
Not a fan of the RGBYO kit or Yellow shifts (reminds me of GMK Nightmare mods, fwiw) but I can see how people want the SOWARE-ish look.
Love the Magenta mod pack, wish it had the TADA pack keys too though so I could use it with my OG Dolch keys to fill a 65% board.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #55 on: Thu, 22 September 2016, 13:09:31 »
The Yellow Shifts is to complete the CMY pack. All the keys will be double-shotted. We are looking into Windows 95 and Diamond Keys.
Offline loud_asian
« Reply #56 on: Thu, 22 September 2016, 18:14:40 »
Hey sherry, would it be possible to add a 1u yellow FN key? I'm a stickler for matching shifts+FNs
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #57 on: Thu, 22 September 2016, 18:21:48 »
+1
I have that added for the RGB kit, and we'll add it for the Yellow Shifts.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #58 on: Fri, 23 September 2016, 01:15:44 »
I have came up with pricing and this is what we are seeing.
Please add in if you want to see the kits together or separate!
Base: $135 - 148 keys
Magenta+Shift Pack: $56 ~45 keys
RGBYO: $42 - 29 keys
Offline HelixDan
  • a SB player
« Reply #59 on: Fri, 23 September 2016, 01:34:04 »
135 + 56 + 42 = $233, extra $34
i had planed to buy 5 sets(5*$199=$995),but now... 5*$233=$1165, do not know what i should say something, may be not in  :confused: :confused: :confused:
====== Welcome to Matrix Lab ======
HHKBClack ClickTopre
RealForce 87uClack ClickTopre 55g
LZ-CPGMK Red AlertBrown
Minila AirGranite DSABrown
?????Red
Offline cmd
« Reply #60 on: Fri, 23 September 2016, 01:34:32 »
Hell ya! Love it  :-* :-* :-*
Offline anthonyooiszewen
« Reply #61 on: Fri, 23 September 2016, 03:49:18 »
Will we be able to do this and the $199 bundle price? I'd much rather just get everything if it ends up being $34 cheaper. I think having both options would be good. Might be a bit of a hassle on your end, but it will provide people with enough incentive to go all in on the bundle, without neglecting those who just want the separate kits.
Offline vincentalpha
« Reply #62 on: Fri, 23 September 2016, 11:00:44 »
I hope you can change windows icon to CODE icon, that would be more interested for multi OS user.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #63 on: Fri, 23 September 2016, 14:01:29 »
I can't offer both options because it'll be less likely one will hit and the other will not.
Offline Vigrith
« Reply #64 on: Fri, 23 September 2016, 14:16:03 »
Apologies for the slight offtopic Sherry but any rough ETA on when you'll be working on the JD40 kits? One of those and then a set of Sky Dolch will surely be my next purchases, hope you guys had a good time at the meet last weekend!
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #65 on: Fri, 23 September 2016, 14:39:35 »
I would definitely be in on this set as long as it includes a 6.25u spacebar or the option to buy one. Gotta make sure this can fit my 60%s & TKLs! ;D
Offline kawasaki161
« Reply #66 on: Fri, 23 September 2016, 15:07:34 »
It does
104 US ANSI means the standard 104 key layout with 1,25u and 6,25u bottom row
Offline Rob27shred
« Reply #67 on: Fri, 23 September 2016, 16:11:41 »
It does
Awesome, thanks for the heads up! I was assuming that it did come with one, but one of the pics of a full board threw me off. Right now I only have 60%s, a 65%, & a TKL, figured best to ask now during IC just in case. Although I do feel kinda dumb as you are right about ANSI. I'm still fairly new to mech KB collecting so bear with me, I'm learning!
« Last Edit: Fri, 23 September 2016, 16:14:49 by Rob27shred »
Offline codedisorg
« Reply #68 on: Fri, 23 September 2016, 16:50:04 »
I'd be in for the base and magentas regardless. If the $199 bundle was available I'd drop the extra $8 for all 3 in a heartbeat.
Offline soilheart
« Reply #69 on: Fri, 23 September 2016, 16:55:19 »
Not a fan of the mixed textless and icon+text shifts (because of the difference in vertical alignment of the icon between the two).
Not a huge issue for me personally at the moment as most of my boards are 1.25u + 1.75u, but still limits the use of the keys for us that like a more coherent look. (A good compromise between having 8 shifts is to add one textless 2.75u (for ISO users) and one icon+text 1.75u (for ANSI users)).
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
Offline KHAANNN
« Reply #70 on: Fri, 23 September 2016, 17:07:06 »
In the past I always wanted Penumbra-like unique modifiers for GMK keycaps, but if you are not a Windows-fan, it's almost impossible for such a dream to come true - especially for non-standard layouts
I just checked the Sky Dolch II keycaps to see whether any ideas spark up, for personal usage
It seems to me that there are 2 different products, One Sky Dolch + CMY (soft colors) - and second, the RGBYO modifiers (strong colors) - which could be nice for Windows GMK Dolch users to buy as an add-on
I'm wondering how the buyers intend to mix and match the keycaps, would love to see keyboard-layout-editor sketches if anyone has any
Offline honeynugget
    • /u/honeynugget on reddit
« Reply #71 on: Fri, 23 September 2016, 18:43:05 »
as someone who would want all the keys in the mockups, I prefer the $199 option for all the keys
Offline megaforce
« Reply #72 on: Fri, 23 September 2016, 18:45:29 »
god bless.
Thanks Sherry!
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Dreamre
    • kbdlife
« Reply #73 on: Fri, 23 September 2016, 23:37:10 »
We need an add-on kit for the original Dolch with 75% and etc!
Offline Endeavour1934
« Reply #74 on: Sat, 24 September 2016, 13:17:42 »
Diamond FTW!  ;D
Offline atoms
« Reply #75 on: Sat, 24 September 2016, 23:42:42 »
Modern is SOOOOO important!
Modern menu key, and Win8 keys are so needed, imo.
If you offered them in one of the mod sets, I'd definitely buy that as well :)
Offline Saint Chewy
« Reply #76 on: Sun, 25 September 2016, 09:35:33 »
I agree but it seems like sherryton is set on having win95. Don't know why we couldn't do both and make everyone happy.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #77 on: Sun, 25 September 2016, 17:19:48 »
I'm interested in CODE/DIAMOND/WIN95.
Offline shower_king
« Reply #78 on: Sun, 25 September 2016, 23:37:07 »
first i want the base kit and mod to be departed for participants to have more choices when joining this GB.
After the price given , i prefer to buy a complete set with base and mod at a lower price.
PS:IF the price of  all of seperate kits are the same with complete set, i always  like them be sold at seperate ones.
if seperate kits' price is much higher than a complete set's ,i would prefer to buy one set at a lower price.
« Last Edit: Sun, 25 September 2016, 23:47:08 by shower_king »
Offline KyleZhuang
« Reply #79 on: Sun, 25 September 2016, 23:44:47 »
Interested in diamond
REALFORCE 104 Pro-30
« Reply #80 on: Mon, 26 September 2016, 15:43:37 »
Would kill for Win95.
Offline duynguyenle
« Reply #81 on: Mon, 26 September 2016, 15:53:50 »
Win 8 icon would be good plz  :))
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #82 on: Wed, 28 September 2016, 17:27:11 »
Hey Guys, this group buy might run towards the end of Q1 '17. There's a lot of GMK sets going on and there's a lot to finish right now at Originative. We would like to push out Skeletor and Modern Beige before I get to this set again. I'll update you guys more as time goes by!
Thanks a lot for keeping up with us :)
Offline duynguyenle
« Reply #83 on: Wed, 28 September 2016, 17:31:12 »
That might end up working out a lot better for many of us actually, what with all the craziness going on with so many GMK sets within the last 60 days. P/S if I have a question about my originative order, where would be the best place to contact you guys? Should I PM here or email you at your Originative email address?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #84 on: Wed, 28 September 2016, 17:38:01 »
Please send us an e-mail to contact@originativeco.com :)
Yeah, lots of GMK craziness. We have lots of GMK incoming still, so this one should hold off.
I have a set of Sky Dolch already, so I'm pretty comfortable. Ido want my Modifiers though...
« Last Edit: Wed, 28 September 2016, 19:47:44 by sherryton »
Offline Jedi
« Reply #85 on: Wed, 28 September 2016, 18:23:10 »
You are fantastic Sherryton. A lot of transparency in all the activity happening at OriginativeCo. Very impressed with your solid communication and quick delivery process. Much faster than any other group buy system out there.
Keep up the great work :thumb:
Offline shower_king
« Reply #86 on: Wed, 28 September 2016, 19:44:22 »
sigh for my wallet. i will save money for sky dolch Ⅱ and other GMK s
Offline Vigrith
« Reply #87 on: Wed, 28 September 2016, 19:45:56 »
That's actually very good news, Sherry. With all the cool sets coming out as of late (still need to buy a Hyperfuse from you guys, soonTM) waiting for the first quarter of 2017 is going to be a huge relief.
Thank you for keeping us updated dude!
Offline gadzkun
« Reply #88 on: Wed, 28 September 2016, 21:06:54 »
Glad to hear it will run on q1 17 my wallet will ready at that time xD
Im already have sky dolch thou but this one is on another lvl.
Offline Cony_WANG
« Reply #89 on: Thu, 29 September 2016, 00:42:36 »
win8 or diamond keys please. IMO, the win95 pad-print winkeys are soooooooo ugly and stupid.
Offline ntitco1
« Reply #90 on: Thu, 29 September 2016, 07:24:29 »
Any chance of combining this with the sky dolch accent? I'm really digging the color scheme  :p
Offline Dyaems
« Reply #91 on: Wed, 05 October 2016, 06:11:44 »
$199 for 219 keys? I'm in:thumb:
I would prefer win8 logo or other logo as well. Even the diamond logo from HHKB would be nice
   B.face X2
  65g Zealios
Offline roostrc0gburn
  • its just plastic
« Reply #92 on: Wed, 12 October 2016, 12:23:44 »
sounds like we are doing kits now instead of the bundle, right?
i would much prefer kits. otherwise, i would have to try and sell my current sky dolch set to buy the bundle. probably would lose some money on that deal. thanks for putting out another awesome add-on to this great set, sherryton!
Offline Saint Chewy
« Reply #93 on: Wed, 12 October 2016, 14:15:23 »
So is the group buy happening now?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #94 on: Wed, 12 October 2016, 14:29:50 »
No, there's no group buy. Going straight into production +1
Offline duynguyenle
« Reply #95 on: Wed, 12 October 2016, 14:36:29 »
Sherry you're killing me! I thought GB was gonna happen next year like you said earlier, have no money to buy this now and I guess by the time I have, the price will go up? (usually you guys put prices up once order is submitted to GMK right?)  :( :( :(
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #96 on: Wed, 12 October 2016, 14:37:42 »
Right, some people have forced my hand. The price will go up when the sets arrive. That's going to be towards January. We are planning to buy approximately 300 sets, so I believe that is enough to go around.
Offline duynguyenle
« Reply #97 on: Wed, 12 October 2016, 14:40:22 »
I see, so this is because of the other Dolch set GB? Understandable then. If possible could you guys do a mock up or render that shows the finalised keyset list including all the child kits? I would like to see which child kit contains what keys especially the coloured ones.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
« Reply #98 on: Wed, 12 October 2016, 14:41:20 »
Will be asking thesis for his time on all the mock ups. He's been a little busy, so I'll see what he says tonight :D
  • its just plastic
« Reply #99 on: Wed, 12 October 2016, 14:48:44 »
i dont see the colored mods and other child kits on the website... is originative just re-running sky dolch v1 right now?
