Author Topic: Long time listener first time caller  (Read 2244 times)
Offline Happyham
« on: Tue, 20 September 2016, 08:33:55 »
Hello,
Finally decided to make an account here because well i need moar keycaps! Currently trying to decide if my next keyboard should be a 75% or a TKL both are really appealing either way it will be rocking 65g Zealios. Currently i have a Planck with MX blues and a WASD Code with MX Greens.
Offline Fictiouz
  • That "White" Guy
Re: Long time listener first time caller
« Reply #1 on: Tue, 20 September 2016, 08:38:08 »
Welcome!
Either way they provide the same functionality really, so it's more about whether or not you want something a little more compact. Good choice on the switches though typing on them as we speak!
Offline Happyham
« Reply #2 on: Wed, 21 September 2016, 10:20:17 »
Well thanks for the info, I can definitely say that i need arrow keys and Home, Delete, Pg up and Pg Down. I'd like to retain the F row but i'm slowly making may Planck a macro board so it could take the place of the F row
Offline Jokrik
« Reply #3 on: Wed, 21 September 2016, 20:51:21 »
Welcome to wallethack :)
A TKL sounds like the perfect addition to your collection, a 75% you really need to give it an actual try since the keys are too packed together (especially the arrow). I'm a heavy arrow user as well and I find the arrows on such 75% board is hard to adjust
Offline Happyham
« Reply #4 on: Fri, 23 September 2016, 16:02:37 »
Sorry for the slow reply
My major concern on this is actually the shift key. I usually reprogram Caps Lock as control and heavily use the right shift when i'm not gaming. My question is how hard is it to get used to a 1.75u shift key?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Fri, 23 September 2016, 18:54:43 »
1.75u shift key still has quite a bit of room for key presses. If you naturally press in the center or left corner of a full sized Rshift you probably won't have to adjust to compensate for the smaller size. Would only be a problem if you press near the right edge of the key afaik.
