Author Topic: GH60 Plate DXF?  (Read 7707 times)
Offline 0100010
  • Not Sure
GH60 Plate DXF?
« on: Tue, 20 September 2016, 14:29:03 »
Anyone have a DXF for a GH60 plate (of any key layout flavor)?
Offline xondat
  • i'm not a star
Re: GH60 Plate DXF?
« Reply #1 on: Tue, 20 September 2016, 14:54:42 »
You can build one on KLE and then put the raw data into Swill's plate generator.
Offline 0100010
  • Not Sure
Re: GH60 Plate DXF?
« Reply #2 on: Tue, 20 September 2016, 15:10:33 »
If I do, will it have the proper screw mount locations and rounded corners?
Offline xondat
  • i'm not a star
Re: GH60 Plate DXF?
« Reply #3 on: Tue, 20 September 2016, 15:25:14 »
If you select the poker plate style and rounded corners in swills builder, yes.
Offline 0100010
  • Not Sure
Re: GH60 Plate DXF?
« Reply #4 on: Tue, 20 September 2016, 15:26:55 »
Happen to know what mm radius to input for the corners?
Offline xondat
  • i'm not a star
Re: GH60 Plate DXF?
« Reply #5 on: Tue, 20 September 2016, 15:27:44 »
I don't, something like 3mm would probably be appropriate as it's the same as the holes.
Offline 0100010
  • Not Sure
Re: GH60 Plate DXF?
« Reply #6 on: Tue, 20 September 2016, 17:00:17 »
OK, thanks!  Will look around a bit.
Offline 0100010
  • Not Sure
Re: GH60 Plate DXF?
« Reply #7 on: Tue, 20 September 2016, 18:07:10 »
Is it kosher to place a costar spacebar stabilizer above the switch (near the ZXCV row), instead of below (bottom edge of the board)?
EDIT : Kind of hard to tell, but the costar stab holes are offset in this DXF above the switch, instead of below.
« Last Edit: Tue, 20 September 2016, 18:09:39 by 0100010 »
