Author Topic: [Alveeno Caps]Yet another artisan maker thread  (Read 13088 times)
Offline alveeno
« on: Thu, 22 September 2016, 13:43:16 »
I have decided to document my crafting journey here! Hopefully I can inspire someone else to begin this hobby :)
My setup:
Vacuum Chamber - http://www.ebay.com/itm/201581802171
Super Sculpey
Quantum Silicones 262
Innovative Polymers IE-3075
Also bought some Smooth-On OOMOO 30 Silicone Rubber, haven't tried using it yet tho
Vacuum Chamber is okay, it reaches near -25 inHg to -28 inHg, also when I unpacked it there was oil all over the vacuum pump :( oh well.
After ordering the vacuum chamber, I read that if you had to choose between a vacuum chamber and pressure pot, go with the pressure pot. For now, I'll stick with the vacuum chamber and will grab a pressure pot once I master hand pouring :D
Making the mold:
Making my mold with Super Sculpey and legos MegaBlocks :(
Silicone in the vacuum chamber
Silicone after being degassed
After pouring, I poured in bottom right corner at about ~20 inches above
Some air bubbles but thats okay
« Last Edit: Tue, 01 November 2016, 20:21:02 by alveeno »
Offline pinkizhip
  • No, you're a towel.
    • Prime Caps
Re: Yet another artisan maker thread
« Reply #1 on: Tue, 27 September 2016, 11:56:05 »
Thanks for the pics. Keep em coming  :D
Offline alveeno
« Reply #2 on: Thu, 06 October 2016, 21:33:38 »
Offline alveeno
Re: [Alveeno Caps]Yet another artisan maker thread
« Reply #3 on: Sat, 08 October 2016, 12:58:31 »
Some recent experiments of mine, first attempts at double shot
Offline alveeno
« Reply #4 on: Thu, 20 October 2016, 11:02:58 »
Some more casts
« Reply #5 on: Thu, 20 October 2016, 12:21:04 »
Looking good - nice bright colours and no bubbles that I can see, and as they're trans that should be easy!
Great design to practice your doubleshots so give them another go :thumb:
Offline alveeno
« Reply #6 on: Thu, 20 October 2016, 17:13:29 »
Doubleshot https://imgur.com/gallery/Q1dGH
Learning lots, next batch will be better :)
Offline FioraCorp
  • AKA ABC
    • My insta
« Reply #7 on: Fri, 21 October 2016, 02:19:33 »
Hey there!  Had to come find you on GH after seeing your pink and black doubleshot on reddit.  I'll be watching and I'm stoked for your sale :)
Offline alveeno
« Reply #8 on: Sat, 22 October 2016, 13:34:00 »
Thank you for the kind words! Cute cat :)
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #9 on: Sun, 23 October 2016, 18:52:28 »
Entered.
I'm in Canada. Will PM you on reddit later on  ;)
GLWS
Offline alveeno
« Reply #10 on: Sun, 23 October 2016, 19:18:34 »
Sounds good, thank you man! Will keep an eye out for your pm.
Offline alveeno
« Reply #11 on: Thu, 27 October 2016, 21:38:13 »
First time trying to match colors with a set, a little off.
Offline ArchDill
« Reply #12 on: Thu, 27 October 2016, 22:19:02 »
Missed out on the sale but I like your caps! Keep up the good work!
Offline alveeno
« Reply #13 on: Fri, 28 October 2016, 14:09:54 »
Thank you!
Here's my first attempt at triple shot
« Last Edit: Fri, 28 October 2016, 14:12:15 by alveeno »
Offline Raenbo
  • IG: @aero_keys
« Reply #14 on: Fri, 28 October 2016, 17:35:56 »
Got mine today! :)
They look good and they fit on the stem really well! The colors are great.
But I have a little feedback (from a fellow maker).
Some sanding goes a long way in terms of cleanliness on the backside. Just to get rid of the sprue marks is enough in my opinion. The key on the left is one of ETF's, which is like the ultimate clean backside, and is something I'm starting to compare my caps to.  But overall your caps are really good looking, especially for your first sale. Keep up the good work and always strive to keep improving :)
Offline alveeno
« Reply #15 on: Fri, 28 October 2016, 21:59:25 »
Wow, didn't know you were in my sale! I forgot to collect reddit/geekhack usernames on the form  :))
Yeah, I had some sanding sponges but they didn't work very well, I tried to clean it up as much as possible! What do you recommend for sanding?
Anyways, I agree with your points. I'm holding a higher standard for my next sale in terms of quality of the caps. The goal is to have a clean backside :]
Offline Raenbo
  • IG: @aero_keys
« Reply #16 on: Fri, 28 October 2016, 22:35:24 »
We've been using sandpaper from Amazon
Starting from 400 to get the sprue marks off, then going up in grit to get the cap smoother and smoother. We stop around 1000. Sanding is probably the least fun part out of the whole cap-making process, but in the end it's worth it to up the quality of your caps :)
Here's one of Binge's streams, where you can watch him work on sanding. You can just watch a few minutes to get the idea of it.
Offline ArchDill
« Reply #17 on: Fri, 28 October 2016, 23:15:16 »
Thank you!
Is this watermelon colorway?
« Last Edit: Fri, 28 October 2016, 23:18:26 by ArchDill »
Offline alveeno
« Reply #18 on: Sat, 29 October 2016, 00:54:01 »
Thank you!
Yessir.
Paw Cap v2
« Last Edit: Sat, 29 October 2016, 12:42:54 by alveeno »
Offline CamRank1
« Reply #19 on: Mon, 31 October 2016, 20:17:54 »
Got mine today, very happy! Looking forward for some White ones :P
Offline alveeno
« Reply #20 on: Tue, 01 November 2016, 19:26:36 »
Paw V2, coming soon..
Also, it's a little dirty cuz I just sanded it, D:
« Last Edit: Tue, 01 November 2016, 20:21:36 by alveeno »
Offline Stevec
« Reply #21 on: Thu, 03 November 2016, 19:00:11 »
Any plans for your next design, after the Pawcap v2?
Offline alveeno
« Reply #22 on: Fri, 04 November 2016, 01:42:04 »
I'm open for suggestions!  :))
Some other makers are creating elaborate sculpts, but I'm more of a minimal-ist/simple kind of guy.
Offline brizzzle
  • ipee9932cd
« Reply #23 on: Fri, 04 November 2016, 02:36:00 »
I think it would look nice centered on a DSA cap.
Offline alveeno
« Reply #24 on: Fri, 04 November 2016, 02:44:10 »
I've been considering making DSA caps, definitely don't see a lot of DSA artisans.
Offline GreyAmbience
  • I can stop when ever I want
« Reply #25 on: Fri, 04 November 2016, 06:30:21 »
I like the idea, but...
Interested in criticism?
I don't like that it is off-center and it looks to much like play dough on top of a cap.
I really feel like this is the standard now:
It might be that ETF is really skilled, but with caps like the moondrops around, anything less well made just looks extra bad in comparison.
Hope I didn't make anyone sad, just wanted to share my honest opinion.
Keep up the good work :)
« Last Edit: Fri, 04 November 2016, 06:32:15 by GreyAmbience »
Offline alveeno
« Reply #26 on: Fri, 04 November 2016, 10:07:47 »
Thanks for sharing! I'll do my best to try and improve, I'm pale in comparison to ETF :-X
Offline dgneo
  • Supervillain
« Reply #27 on: Fri, 04 November 2016, 10:09:12 »
Cheap and readily available at any beauty store.
Offline alveeno
« Reply #28 on: Fri, 04 November 2016, 17:55:48 »
Ooh, smart. I'll try and grab some. I grabbed some sandpaper raenbo mentioned and that worked waaay better than my stupid sanding sponges. :)
Offline Raenbo
  • IG: @aero_keys
« Reply #29 on: Sun, 06 November 2016, 23:21:14 »
Aren't we all heh o-o''
Offline alveeno
« Reply #30 on: Sun, 20 November 2016, 23:39:26 »
Let's get festive
