Author Topic: Gateron black batches help please!  (Read 1754 times)
Offline ItsBarney01
« on: Thu, 22 September 2016, 16:02:12 »
Hi everyone,
I was doing some research on gateron blacks, and found some things pointing to the fact that the newer ones (with black bottom rather than milky) are superior. Is this true?
Here is the post where I saw this: https://geekhack.org/index.php?topic=80545.0
In Australia it is much easier to buy the milky ones, as you can get them within Australia so it is much cheaper. If anyone knows where to buy the newer ones (in Australia) or if it even matters please tell me!
Thanks a lot  :thumb:
^^^Click for instagram^^^
Offline Jumie
Re: Gateron black batches help please!
« Reply #1 on: Tue, 27 September 2016, 22:23:26 »
I use both version of gateron black. The milky bottom one is 55g while the clear top is 50g. For me the clear top is the better simply because it is less heavy.
