Author Topic: Geekkeys Dye-sub PBT's  (Read 3594 times)
Offline KHAANNN
« on: Thu, 22 September 2016, 22:35:41 »
http://www.geekkeys.com/geekkeys-cyan-grey-dyesub-thick-pbt-full-keyset/
I've had a geekkeys laser-etched PBT set a long time ago, really didn't like that set, because of the laser-etching (not a good method) - and mainly because the keycaps were see-thru, the stems were visible, they were also damp from humidity, again, probably from laser-etching - but apart from these, they are unique neon-like keycaps
Just discovered the above set while looking whether the GMK Cyan Esc is in stock (http://i.imgur.com/TvKcdA1.png)
The set looks pretty good
Anyone tested/bought one of these?
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
Re: Geekkeys Dye-sub PBT's
« Reply #1 on: Thu, 22 September 2016, 22:43:44 »
Im also curious about this, I couldnt get on that that drop in MD with the grey/cyan. They are priced a bit high but considering its from a vendor, i assume its normal.
They also have some pbt keycaps with cherry profile with different dyesub colors on sale. which are also tempting :D
Hope to hear reviews on their keycaps especially if they are as thick as the ones varmilo makes which are my baseline for pbt thickness.
Offline nyunyu
« Reply #2 on: Fri, 23 September 2016, 07:08:34 »
F and J caps are scooped, so the keycap manufacturer is Gateron.
Dyesubbed legends are similar to EnjoyPBT sets.
Maybe Shadovved can help you, as he had an EnjoyPBT GB recently: https://geekhack.org/index.php?topic=78563
But there was no cyan/gray option there.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #3 on: Fri, 23 September 2016, 09:16:29 »
By the way, they look very similar to this set that failed to drop :(
https://www.massdrop.com/buy/varmilo-custom-cyan-keycap-set
