Author Topic: What keycap profile is this? (Filco Majestouch Tenkeypad)  (Read 7147 times)
Offline Tangtawan
« on: Fri, 23 September 2016, 08:44:59 »
Hi, i have been using the Filco Majestouch Tenkeypad for awhile now, and is currently looking to replace its keycap with aftermarket one. The problem is.. i have tried OEM profile and the R4 caps still seems a bit too low for the top row of this keypad. what kind of profile should i be looking into?
Thanks
« Last Edit: Fri, 23 September 2016, 08:47:52 by Tangtawan »
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
Offline user 18
Re: What keycap profile is this? (Filco Majestouch Tenkeypad)
« Reply #1 on: Fri, 23 September 2016, 08:48:45 »
Hi, i have been using the Filco Majestouch Tenkeypad for awhile now, and is currently looking to replace its keycap with aftermarket one. The problem is.. i have tried OEM profile and the R4 caps still seems a bit too low for the top roll of this keypad. what kind of profile shohld i be looking into?
Thanks
It is OEM profile, as far as I'm aware. The issue is that not all the profiles we call OEM are actually identical. Perhaps someone can recommend a specific manufacturer that works well for your needs? I typically use Cherry profile, which is a bit lower than what you have in your picture.
Avatar by ashdenej
Offline Tactile
« Reply #2 on: Fri, 23 September 2016, 08:58:33 »
This might help you decide.
149004-0
REΛLFORCE
Offline Tangtawan
« Reply #3 on: Fri, 23 September 2016, 09:14:26 »
Thanks
yes, it does look like i have an OEM profile, R1 R2 R3 R4 is identical to OEM.. but the top row seems odd and i dont know what kind of key are those? maybe it specifically made for this majestouch tenkeypad?
Offline keyladding
« Reply #4 on: Fri, 23 September 2016, 10:56:05 »
Yes, it is.
