Author Topic: what OG set?  (Read 4096 times)
Offline alienman82
what OG set?
« on: Sun, 25 September 2016, 16:33:13 »
removed.
« Last Edit: Thu, 01 March 2018, 14:08:19 by alienman82 »
Re: what OG set?
« Reply #1 on: Sun, 25 September 2016, 16:45:39 »
Desko. It's not OG though. The keys with sublegends are BSP and the normal ones are doubleshot. He's mixed it with what looks like a SAD set though.
Offline alienman82
Re: what OG set?
« Reply #2 on: Sun, 25 September 2016, 18:07:44 »
removed.
« Last Edit: Thu, 01 March 2018, 14:08:17 by alienman82 »
Offline ideus
  • Björkö.
Re: what OG set?
« Reply #3 on: Sun, 25 September 2016, 18:24:49 »
Where did you get it? or isn't yours?
Offline alienman82
Re: what OG set?
« Reply #4 on: Sun, 25 September 2016, 18:43:01 »
removed.
« Last Edit: Thu, 01 March 2018, 14:08:14 by alienman82 »
Offline ba7777
what OG set?
« Reply #5 on: Sun, 25 September 2016, 18:48:40 »
This kind of OG set could be fetched in taobao.com
Offline ideus
  • Björkö.
Re: what OG set?
« Reply #6 on: Sun, 25 September 2016, 19:35:30 »
Link? or lie?
Offline ba7777
what OG set?
« Reply #7 on: Sun, 25 September 2016, 21:31:29 »
« Last Edit: Sun, 25 September 2016, 21:38:55 by ba7777 »
Offline Giorgio
Re: what OG set?
« Reply #8 on: Mon, 26 September 2016, 07:25:53 »
Offline duynguyenle
  • Personal text? What personal text???
Re: what OG set?
« Reply #9 on: Mon, 26 September 2016, 12:42:34 »
https://2.taobao.com/item.htm?id=526231042027&ns=1&abbucket=20#detail
why should I lie for this?
link doesn't work
Works for me, just takes a while to load.
Does look very much like Alienman's picture, but the front-printed legends are not exactly the same on some of the keys
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline ideus
  • Björkö.
Re: what OG set?
« Reply #10 on: Mon, 26 September 2016, 12:56:03 »
It's very expensive.
Offline alienman82
Re: what OG set?
« Reply #11 on: Mon, 26 September 2016, 13:04:16 »
removed.
« Last Edit: Thu, 01 March 2018, 14:07:56 by alienman82 »
