Author Topic: [help] Programming Teensy 2.0  (Read 3528 times)
Offline 27.9.2016
« on: Tue, 27 September 2016, 15:29:49 »
First i wanna say hello to this community  ;)
I am thinking that i will make custom 60% keyboard with Teensy 2.0 for my last project in school (i have basic arduino knowledge) and now i have some questions:
-Can you programme Teensy 2.0 completely in arduino language? (i know that arduino and C are similar)
-Can i start from zero program because i have to explain the process? (What specific line do)
-Can program be in one file or it has to be splitet?
Thank you for helping me :thumb:
And sorry for my bad english  :confused:
Offline deductivemonkee
  • Professional Lurker
Re: [help] Programming Teensy 2.0
« Reply #1 on: Tue, 27 September 2016, 15:32:16 »
Check out tmk, qmk, and easy avr.
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline henz
  • What?
« Reply #2 on: Tue, 27 September 2016, 15:33:04 »
i did something similar a while ago. ill edit in thread when i find it
edit: https://geekhack.org/index.php?topic=71890.0
Offline 27.9.2016
« Reply #3 on: Tue, 27 September 2016, 15:42:09 »
Wow nice project man.
You sad "Then i made a boobo, i got a teensy 3.1, which i then found out was not supported."
Did you use Teensy 2.0 then or 3.1?
Offline henz
  • What?
« Reply #4 on: Tue, 27 September 2016, 15:44:28 »
ive done both since then, you can code in aurdino for both platforms. The idea at the time was to use tmk, but i bought the wrong teensy and tmk had no support for teenies in the 3 series, so i wrote my own firmware.
Offline 27.9.2016
« Reply #5 on: Tue, 27 September 2016, 15:53:50 »
Thanks for info  :)
