Author Topic: How to clean GMK keycaps  (Read 18473 times)
Offline Giorgio
« on: Fri, 30 September 2016, 06:02:39 »
How do you clean your GMK abs keycaps when you don't have time to remove them from the keyboard?
Do you use isopropyl alcool, or a less strong disinfectant agent?
According to the attached pdf
http://www.geotechenv.com/Reference_Pages/chemical_compatibility_table.pdf
on ABS plastic you can use:
Isopropyl Alcohol
Hydrogen Peroxide (dilute)
Sodium Hypochlorite 20%
But you can't clean them with Ethyl Alcohol (which is the kind of alcohol that you can drink).
https://geekhack.org/index.php?topic=68721.0
« Last Edit: Fri, 30 September 2016, 06:04:25 by Giorgio »
Re: How to clean GMK keycaps
« Reply #1 on: Fri, 30 September 2016, 06:43:46 »
You really should always remove caps to clean them.
Offline Diokhan
« Reply #2 on: Fri, 30 September 2016, 07:10:46 »
So dont drink your vodka near your keyboard, check.
« Reply #3 on: Fri, 30 September 2016, 11:13:23 »
Wait. You actually own GMK keycaps?  :-\
Offline 27
  • The Maple Man
« Reply #4 on: Fri, 30 September 2016, 11:27:37 »
I use denture tablets in warm water.  Give em a little scrub, and dry thoroughly before putting them back on your board.
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline Vagabond
« Reply #5 on: Fri, 30 September 2016, 14:34:00 »
Are baby wipes OK?
Offline Giorgio
« Reply #6 on: Fri, 30 September 2016, 14:57:50 »
Do you?
Offline 27
  • The Maple Man
« Reply #7 on: Fri, 30 September 2016, 14:58:56 »
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #8 on: Fri, 30 September 2016, 14:58:57 »
i think someone mentioned that rubbing alcohol removed pad printing for gmk caps.  i would stick to a dab of mild dishwashing liquid/hand soap with damp cloth.
but the best way for me is to use a cheap ultrasonic cleaner and throw the caps in with mild soap.
Offline Giorgio
« Reply #9 on: Sat, 01 October 2016, 01:32:26 »
« Reply #10 on: Sat, 01 October 2016, 20:44:27 »
Soap and warm water in a bowl. Move them around for 5-10 minutes. Repeat once every 3 months.
« Reply #11 on: Sun, 02 October 2016, 04:00:06 »
You won't be able to get them properly clean without removing them from the keyboard.
Offline Giorgio
« Reply #12 on: Sun, 02 October 2016, 07:34:00 »
I agree, but using it at the office, compromises are necessary :-)
Offline Moistgun
  • Slippery When Wet
« Reply #13 on: Sun, 02 October 2016, 08:49:33 »
Is it bolted to the desk at work?
Offline Giorgio
« Reply #14 on: Sun, 02 October 2016, 09:36:33 »
Should I take it home to clean it? Or should I close myself in my office with a basin filled with water? Or should I clean it in the main hall, cleaning each key cap with a tooth brush?  :))
Offline Moistgun
  • Slippery When Wet
« Reply #15 on: Sun, 02 October 2016, 10:00:12 »
You should take it home to clean it
Offline duynguyenle
  • Personal text? What personal text???
« Reply #16 on: Sun, 02 October 2016, 10:22:09 »
I take my board home and clean the caps properly with denture tabs and a soft bristled brush. For quick touch-up at the office, wetwipes usually do fine
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline KHAANNN
« Reply #17 on: Sun, 02 October 2016, 14:26:11 »
I just carve out the surface and side of the keycaps with my nails and move on
« Reply #18 on: Sun, 02 October 2016, 14:41:59 »
I just take them off my board and scrub them in some warm soapy water like any other keycap. Why would GMK caps be any different?
« Reply #19 on: Sun, 02 October 2016, 21:04:48 »
Just like removing a computer case and blowing the dust out at work from time to time it necessary, so is removing keycaps and cleaning them.
Although I haven't kept one keyboard here long enough to get dirty, and tend to type with clean hands and thus not make it dirty anyway, I haven't needed to clean my keycaps at work (yet).
Although should I need to, a bowl of warm water placed discreetly at the other end of my desk would not be too far out of place.
Offline ideus
  • Björkö.
« Reply #20 on: Sun, 02 October 2016, 21:24:01 »
Just wash them with dish soap and plenty of water.
Offline Vagabond
« Reply #21 on: Tue, 04 October 2016, 09:47:52 »
Offline Giorgio
« Reply #22 on: Tue, 04 October 2016, 10:28:19 »
Antibacterial!
https://www.amazon.com/Read-Right-KeyWipes-Keyboard-RR1233/dp/B001GXHHNS
premoistened with what? Not necessarily something not dangerous for plastic.
Offline vaughno
Unikorn | Orion v3 | GSKT-00
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #24 on: Tue, 03 September 2019, 17:16:15 »
Just use ammonia free glass cleaner sprayed on a rag that won't shed real bad & wipe the tops of the keys off for a quick clean. Although as most others recommended if they are really dirty taking the board home, removing the caps, & soaking them in warm water with a denture tab or some mild dish soap, then scrubbing them with a soft toothbrush or soft rag is a much better way to clean them. The best & easiest way is toss them in an ultrasonic cleaner with a denture tab or tiny bit of mild dish soap, although ultrasonic cleaners skyrocket in price with the size of the tub & a cheap one for cleaning jewelry will not hold a quarter of a GMK set in one go.
