Author Topic: Greetings from Tommy  (Read 3210 times)
Offline Tommy
« on: Fri, 30 September 2016, 09:35:09 »
Hi, it's very pleased to meet all the keyboard lovers here.
I'm join this forum to find a suitable keyboard for myself.
Here's my daily using scenario of keyboard:
1. Most time working on macOS, sometimes on Windows
2. Write personal blog posts
3. Programming
4. Work under Linux/Unix/BSD
5. Non-gamer
The problem I'm facing is:
1.  Seldom mechanical keyboards available on market support Mac system
2. Writing posts, programming for long time, it could be very tired
3. I prefer a Bluetooth connected keyboard other than one with USB cable
4. A mini sized keyboard would be great, as I can bring it everywhere
5. A keyboard can work like HHKB that can easily switched between Mac / Windows
6. It would be great to support both USB / Bluetooth methods at the same time
7. Has internal battery, no matter is size AAA battery or Lithium-ion battery
No sure whether someone got the same idea as me? And you're advices are warmly welcomed.
Thanks.
Offline jaffers
Re: Greetings from Tommy
« Reply #1 on: Fri, 30 September 2016, 09:37:11 »
You wanna see the real meaning of keyboard lover??? ;)
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #2 on: Fri, 30 September 2016, 09:48:00 »
Would a normal HHKB (non bluetooth model) with a hasu bluetooth controller work?
Offline Tommy
« Reply #3 on: Fri, 30 September 2016, 09:53:11 »
Thought that too, but still another controller has to be used.
A GH60 + Bluetooth would a good one.
Offline Twinguin
« Reply #4 on: Fri, 30 September 2016, 12:19:52 »
Hi and Welcome.
What makes you think that? I have several mech boards and they all work fine on my Macs. The KUL even has a switch to set it into Mac-mode. But I only use wired keyboards, cannot speak for BT ones.
There is a curse. They say: May you live in interesting times!, Terry Pratchett
Popsicle KUL ES-87 (MX Blue, DSA) | Sun Ultracomputing Pok3r (MX Brown, DSA) | Nuclear WASD 100% (MX Brown, SA) | Gulf Pok3r (MX Clear, DSA) | Granite JD45 (MX Blue, DSA) | Coffee Core (MX Red, DSA) | Lime Pok3r (MX Clear, SA) | Canvas Vibe (MX Silent Red, XDA)
Offline Tommy
« Reply #5 on: Fri, 30 September 2016, 23:10:08 »
Thank you first.
Most of the mech keyboards I can get here in China are for Windows only, I have to use the System Preferences to switch the "Win" / "Cmd", "Alt" / "Opt" keys.
Because there are a lot of USB cables, DP cables and power cables, so I prefer less cables unless it is a must, like say, power cable.
Hi and Welcome.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6 on: Sat, 01 October 2016, 07:14:36 »
Could check out Varmilo. Supposedly people have had success with the VB87M Bluetooth model. They also have some smaller sized boards that will probably work will with Mac. Mechanicalkeyboards.com has/carries the other models. I think Massdrop sells the bluetooth 87 key. Adding a bluetooth module to a kit or whatever could work too if you can get a case printed/CNCed/lasered/casted or find one that can fit your battery of choice. What about HHKB BT? People seem to love HHKB's BT new addition.
HHKB BT can switch between usb/bt and Win/Mac right?
http://www.smartimports.net/pfu-happy-hacking-keyboard-professional-bt-bluetooth/ (Just a compatibility example - prices are meh)
Offline Tommy
« Reply #7 on: Sat, 01 October 2016, 08:43:18 »
Thank you very much for the information, will definitely look into those products.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Sat, 01 October 2016, 10:28:46 »
Yep, welcome aboard
Offline Twinguin
« Reply #9 on: Sat, 01 October 2016, 10:36:56 »
[ ... ], I have to use the System Preferences to switch the "Win" / "Cmd", "Alt" / "Opt" keys. [ ... ]
I did that in the beginning as well, but meanwhile I leave the keys as the are on the Win Boards, i.e. Alt next to Space and Command/OS keys next to it. Works good for me when composing the German Umlaute (Alt+U then 'aou').
Offline alienman82
« Reply #10 on: Mon, 03 October 2016, 14:00:28 »
removed.
« Last Edit: Thu, 01 March 2018, 14:03:10 by alienman82 »
