Author Topic: Typing speed: HHKB versus MX?  (Read 6692 times)
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« on: Sun, 02 October 2016, 22:06:06 »
Hey all,
Do any of you notice that your typing speed on the HHKB (or other topre switch boards for that matter) is lower than other boards with mx switches?
I've been strictly using only the HHKB pro2 for a couple months now, and only recently began using my poker2 with mx clears after hyperfuse came in. Here's what I discovered: my typing speed on the HHKB is consistently around 85-90 wpm. However, after a few hours typing on the poker2 (to get reacquainted to the non-HHKB layout  ;)) my typing speed jumped up to >100. Honestly, prior to the past couple days I've probably only scored >100 on typing test maybe a handful of times. Now I'm consistently getting >100 wpm. And, when I try to type on the HHKB again, my speed drops back down to 80-90.
What I've noticed is that the topre switches seem to have a greater actuation distance than the mx clears. I suppose the dental-band mod or even hypersphere rings could help with this, although I don't think I mind the additional travel of the topre; I just type slower on them.
Anyway, this post is intended really just to note my observation, not to complain about the HHKB. The classic HHKB "thock," the smooth character of the switches, and the glorious layout of the HHKB are waaaaay too appealing to stop using the hhkb.
Cheers!
Offline Altis
Re: Typing speed: HHKB versus MX?
« Reply #1 on: Sun, 02 October 2016, 23:29:17 »
I find I type quickest on 45g Topre. Doesn't matter all too much if it's HHKB or Realforce 87U, though.
It's very rare that I accidentally  press an adjacent key or only press a key partway down while using Topre due to the intensity of the tactile hump.
Strangely enough, I also seem to type quite quickly and accurately on one of the Apple aluminum keyboards (not the latest ones though).
Offline Polymer
« Reply #2 on: Mon, 03 October 2016, 04:52:14 »
Hey all,
The distance is the same...it could just be you respond faster using Clears....everyone will be different...
Offline xondat
  • i'm not a star
« Reply #3 on: Mon, 03 October 2016, 04:57:12 »
It depends on what I've been using at the time. If I've been using my HHKB for a while, I'm generally quicker as I'm less prone to make mistakes. However, if I use my 78g Zealios I'm usually immediately quicker but overall I make more mistakes.
Edit: Generally average 95 wpm.
« Last Edit: Mon, 03 October 2016, 05:21:03 by xondat »
Offline dgneo
  • Supervillain
« Reply #4 on: Mon, 03 October 2016, 05:09:54 »
Opposite for myself. I find that with my HHKB I can average 105-110wpm, whereas any MX board that I've tried so far, I average around 75-80 wpm.
Offline Fictiouz
  • That "White" Guy
« Reply #5 on: Mon, 03 October 2016, 05:10:14 »
I find I'm consistently quicker on MX vs. Topre due to the way that Topre functions. I find the keystrokes much longer, therefore I feel as though it is taking me longer to type. MX I have used for longer and have gotten used to releasing after feeling the key register (I don't use linears). Needless to say I am more accustomed to MX, but I will see a 5-10 wpm drop when using Topre. I'm sure this could improve with constant use, but Topre seems to be more fatiguing to type on due to the long keystrokes in my opinion.
Offline Erikdayo
« Reply #6 on: Mon, 03 October 2016, 06:28:54 »
I type a little faster on my MX red board than I do my Topre board. My MX board is Reds. But I make less errors on Topre which probably evens things out a bit.
  • Dingo babies
    • IG
« Reply #7 on: Mon, 03 October 2016, 12:14:27 »
Really!? Wow I would have sword that the travel distance was shorter on the clears. I think you're right though, for whatever reason the clears seem to be a bit faster for me. But, I enjoy the HHKB better!
Oh interesting! Maybe I still need more time with the HHKB to adjust to the switches, considering I've used MX for years and only a few months ago began using topre.
Offline oneproduct
  • @Ubisoft
« Reply #8 on: Mon, 03 October 2016, 18:26:03 »
I'm a bit faster on cherry reds than anything else. I imagine the lighter force lets you sort of dance over the keys a bit faster. Not sure how I fare between brown and topre though, which are the other two switches I like.
Layout: Colemak
Offline klennkellon
  • I like bottoming out
« Reply #9 on: Mon, 03 October 2016, 23:51:29 »
My fastest WPM is on MX Blues
Offline fublamchu
  • ㅋㅋㅋ
« Reply #10 on: Tue, 04 October 2016, 13:21:53 »
My fastest is on 45G Topre, but the difference between my Topre speeds and my MX speeds are usually negligible (like a 3-4 WPM difference)
LZ-CE VBlacks
910-CE
Offline Dyaems
« Reply #11 on: Wed, 05 October 2016, 03:40:01 »
My fastest probably is on Gat/MX Blues, because I practiced alot on 45g topre, while getting the same speed on an unpracticed Blues :(
« Last Edit: Wed, 05 October 2016, 03:43:22 by Dyaems »
   B.face X2
  65g Zealios
« Reply #12 on: Wed, 05 October 2016, 04:16:30 »
Yes, but only because HHKB is 45g and I prefer heavier switches.
Offline atlas3686
  • HHKB Elite
« Reply #13 on: Wed, 05 October 2016, 05:33:23 »
I find I am a bit quicker on Topre but I think that's just a matter of being more accustomed to it. Interestingly, although I prefer my 55g Realforce I am actually a little faster on average on my type-s.
Offline Auxo
  • Formerly CJD_Anthony
« Reply #14 on: Wed, 05 October 2016, 06:23:12 »
My typing speed is so slow, around 75-90. I think it has less to do with the switches and just my inability to type very well :')
Offline linch8
« Reply #15 on: Fri, 21 May 2021, 11:44:38 »
I have a similar experience as the OP, I type a bit faster with zealios than I type on topre(HHKB hybrid type s). The gap is noticeable, about 5-10 WPM difference , but I have used zealios a bit longer.
