Author Topic: Using a numpad alongside a TKL  (Read 3089 times)
Offline h1ggs
  • @switzcaps
« on: Mon, 03 October 2016, 13:19:14 »
Hey everybody I'm trying to use an external numpad alongside my tkl - and I'm having a problem with numlock. The TKL's numlock is overriding the one on the numpad, so in order to use the numbers on the external numpad, I need to have numlock on. This then interferes with my keyboard because of the numpad layer that overlays the alphas.
Is there a way I can force the OS to differentiate between these two states? (win 10)
Offline Altis
Re: Using a numpad alongside a TKL
« Reply #1 on: Mon, 03 October 2016, 14:02:16 »
I'm not really sure... but what keyboard are you using?
Sometimes there's a switch that can disable the numpad layer entirely for the keyboard.
Offline Tactile
« Reply #2 on: Mon, 03 October 2016, 14:08:41 »
On my Realforce 87U one of the DIP switches will disable the embedded numeric keypad. OTOH, my Cherry ML4100 - if I recall correctly, it's been a while since I dug it out - has no provision to turn the numpad off.
I don't know of a way to tell any operating system to obey num-lock from this input source but ignore num-lock from this other source. I think it's all or nothing.
REΛLFORCE
Offline h1ggs
  • @switzcaps
« Reply #3 on: Mon, 03 October 2016, 15:40:40 »
Oh snap, I totally forgot the RF had dipswitches - I'm using the RF87 so this should fix my issue. Thanks my dude.
edit: incase anyone is wondering toggle the #3 dipsswitch then unplug and plugin the RF. Works like a charm.
« Last Edit: Mon, 03 October 2016, 15:46:16 by h1ggs »
