Author Topic: Need help/advice on fixing keyboard  (Read 1354 times)
Offline Tornrice
« on: Mon, 03 October 2016, 15:46:24 »
Hello,
I accidently broke the stabilizer for the enter key on my kbv60. I was too excited when pulling the key cap off. Any ideas on how to fix this? Or will I have to remove everything inorder to get to it?
Thanks in advance
Offline Moistgun
  • Slippery When Wet
Re: Need help/advice on fixing keyboard
« Reply #1 on: Mon, 03 October 2016, 15:59:43 »
You MIGHT be able to desolder that switch, and finagle the stab out, then replace it.  Pretty unlikely I think.
Chances are you need to desolder the whole board.
Offline Tornrice
« Reply #2 on: Mon, 03 October 2016, 16:46:23 »
Ouch alright, ill probably just leave it be for the time being. Thanks for the advice
