Author Topic: Customizer Spring  (Read 2104 times)
Offline patrickgeekhack
Customizer Spring
« on: Sat, 16 January 2010, 21:09:47 »
While pulling the keys on my CUstomizer to apply some silicone grease, the spring of the backspace key came off. I'm having a hard time to put it back so that the key will fire. Can anyone point me to how I should proceed to put the spring back?
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Customizer Spring
« Reply #1 on: Sun, 17 January 2010, 09:19:21 »
That happened to me once, except it was much worse. The spring came off and then got between the membrane and the black plastic part with all the key barrels. I had to break a few rivets to get it out and got the key to work. The key doesn't sound right anymore though (probably because of the rivet).
Customizer Spring
« Reply #2 on: Sun, 17 January 2010, 19:05:51 »
I managed to fix the problem about ten minutes after I posted the thread. That being said, while the grease trick does muffle the noise, I think it also changes the feel for the worse. That is just my opinion though. The very sharp change in resistance is just not there anymore. I will probably pull all the keys and spring and remove all the grease when I have some time. The good thing is that keyboard is not my daily driver.
