Author Topic: Had a plate laser cut (Help)  (Read 2246 times)
Offline zanzibar312
« on: Tue, 04 October 2016, 07:37:47 »
So, I have designed and had my first plate cut. I thought I would be smart and use 1/4" (5.588mm) acrylic so that I didn't need to worry about flexing of the plate.
Most of you realize that I made an error not allowing for the cherry MX clips to function, and after getting the switches, now I feel like I just made an expensive mistake.
149745-0
Is there anyway I can apply and adhesive (epoxy/superglue/etc) to hard mount the switches to the plate? I am not worried about replacing the springs or being able to remove the top. Although I already have the plate cut with the extra notches.
Any help is greatly appreciated.
« Last Edit: Tue, 04 October 2016, 07:39:49 by zanzibar312 »
Offline Spaceman1200
Re: Had a plate laser cut (Help)
« Reply #1 on: Tue, 04 October 2016, 07:42:48 »
hot gluing the switches on the back of the plate would work fine
Offline zanzibar312
« Reply #2 on: Tue, 04 October 2016, 07:48:48 »
I hadn't thought about hot glue.
I'll definitely give that a try.
Appreciate the advice.
Offline Charger
« Reply #3 on: Tue, 04 October 2016, 10:23:12 »
its not uncommon for people to order thicker acrylic plates and hot glue the switches, in you may even be able to get away without gluing them if they are a tight fit and you don't plan to remove the caps.
Offline zanzibar312
« Reply #4 on: Tue, 04 October 2016, 10:37:24 »
I have tested the switches in the plate. Unfortunately they are not that tight of a fit. I will try hot glue, and hope it holds well enough.
Offline 27.9.2016
« Reply #5 on: Tue, 04 October 2016, 16:31:27 »
Is this okey for cherry mx and cherry stabilizers?
