Author Topic: Linear Switch Help!  (Read 5113 times)
Offline Fictiouz
  • That "White" Guy
Linear Switch Help!
« on: Thu, 06 October 2016, 13:10:33 »
So I'm in the market for some linear switches after discovering I like Gateron Blacks, but I find them just a little bit to stiff. So my question is, is the 50g rating actuation or bottom out.
I am currently stuck between 65g Linear Zeals, 67g Linears Zeals, or Gateron Blacks. What do you guys recommend?
Help me linear switch experts, you're my only hope.
I also previously tried Cherry Blacks and find them to mushy.
Re: Linear Switch Help!
« Reply #1 on: Thu, 06 October 2016, 13:48:07 »
62g lubed mx reds
Offline Fictiouz
  • That "White" Guy
« Reply #2 on: Thu, 06 October 2016, 13:48:48 »
62g lubed mx reds
I should've said I don't like Cherry Linears :p
Offline henz
  • What?
« Reply #3 on: Thu, 06 October 2016, 13:53:21 »
62g lubed mx reds
Favorite is lubed vintage blacks with 65g. Ma Thang
Also tried putting black stems in gateRon housings. Worked like a charm
Offline eksuen
  • Ambassador of explosions.
« Reply #4 on: Thu, 06 October 2016, 13:54:41 »
The 50g rating is actuation. Gateron switches are all rated for actuation like their Cherry counterparts.
Offline Fictiouz
  • That "White" Guy
« Reply #5 on: Thu, 06 October 2016, 13:55:56 »
Have many of you had experience with Linear Zealio Switches?
Offline eksuen
« Reply #6 on: Thu, 06 October 2016, 13:56:44 »
Unfortunately, no. I'd like to try them, though.
Offline Moistgun
  • Slippery When Wet
« Reply #7 on: Thu, 06 October 2016, 14:03:43 »
I know nick has used them.
Offline Fictiouz
  • That "White" Guy
« Reply #8 on: Thu, 06 October 2016, 14:27:39 »
I'll touch base with him after work then. I got an SS plate for X60 and want to put linears on it and I kinda want to wait for zeal60 r2 to build that plate so I got time.
Offline 27
  • The Maple Man
« Reply #9 on: Thu, 06 October 2016, 14:47:44 »
Linear Zeal switches are identical to Gateron linears AFAIK, since you know... they make them.
« Last Edit: Thu, 06 October 2016, 15:36:12 by 27 »
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline mike52787
  • Alps Aficionado
« Reply #10 on: Thu, 06 October 2016, 15:58:19 »
Alps SKCL green. try it and never use cherries again
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #11 on: Thu, 06 October 2016, 17:39:05 »
yup, this man is correct. Especially considering OP doesn't like Cherry he really shouldn't settle for any MX clones :P .
Offline PollandAkuma
« Reply #12 on: Fri, 07 October 2016, 18:46:46 »
you could get Matias linears and order some heavier springs off of Sprit  :D
Offline zacheadams
« Reply #13 on: Sat, 08 October 2016, 10:11:51 »
To this point, does anyone have a spreadsheet or even raw data that has relative actuation force, bottom out force, etc. for gateron, cherry, and zealio switches?  It seems like it's always one or the other force, but nothing that matches up (and I don't know enough about keyboards to assume there's some conversion).
Offline Moistgun
  • Slippery When Wet
« Reply #14 on: Sat, 08 October 2016, 10:23:43 »
I want to say wasd has graphs of the most common cherry switches, you can then use that as a comparison to the switches you have the weight options, like zealios
Offline eksuen
« Reply #15 on: Sat, 08 October 2016, 11:52:51 »
Link: http://www.wasdkeyboards.com/mechanical-keyboard-guide#best
Offline Niomosy
« Reply #16 on: Thu, 13 October 2016, 17:20:58 »
We've also got those linear 50g and 70g Chinese hall effect switches out and about now.
Offline klennkellon
  • I like bottoming out
« Reply #17 on: Fri, 14 October 2016, 04:26:13 »
SKCL Green Alps would be a great choice, and if you can't find those linear modded SKCM Black or SKCM White feel very similar. Just as smooth as SKCL Green at least (if in good condition)
« Reply #18 on: Sat, 15 October 2016, 16:01:57 »
I really want to find some SKCL Greens :p but I guess looking for Blacks are easier and cheaper.
Are Cherry MX linears universally hated? What if they are lubed? I want to try gaterons but I hated the stems are wobbly.
I'm unsure whether I should go forheavier or lighter ones, seeing as they are linears.
Offline chyros
  • a.k.a. Thomas
« Reply #19 on: Sat, 15 October 2016, 16:08:48 »
Well, no. To each their own, after all. Moreover, not everyone can just get a linear Alps board with ease, which in fairness is a rather massive disadvantage. Not everone enjoys digging through skips :p .
Offline pr0ximity
« Reply #20 on: Sat, 15 October 2016, 18:23:57 »
Gateron Blacks are fine, but Vintage MX Black feel crisper to me. They're easy enough to come by, but I don't know much about what you're looking to do or how much modding you're interested in.
I also have heard stock Gateron springs are quite inconsistently weighted, likely looser manufacturing tolerances.
SKCL are great, just need to find a layout you're okay with and hope they're not dirty. ALPs are easy to get dust in and ruin the SKCL smoothness. Also find some nice ALPs caps, which is nontrivial.
Offline mushman
« Reply #21 on: Sat, 15 October 2016, 21:12:33 »
I came to post the same.  XMIT's Hall Effect 80% group buy is starting soon.
Offline captsis
  • Formerly matt2dlg
« Reply #22 on: Sun, 16 October 2016, 06:57:02 »
Feelios. All the way. Every day.
Sent from my SM-G920V using Tapatalk
Offline Niomosy
« Reply #23 on: Tue, 18 October 2016, 18:59:14 »
Yup, looking forward to that one.  Just waiting to see prices.
